This Product Selection Guide contains information to help select products in the Energy Metering category on DigiKey.com
Energy metering integrated circuits are designed for high-accuracy electrical energy measurement in single, dual, and three-phase power line systems. They measure line voltage and current and can calculate active, reactive, and apparent energy as well as instantaneous rms voltage and current.
SelectionCharacteristics
Input Impedance: Characterizes the impedance of a device’s analog signal inputs.
Measurement Error: Manufacturer’s advertised measurement accuracy.
Voltage - I/O High: Characterizes the Lower range of voltage allowed on the device’s input/output pins while in a Logic High state.
Voltage - I/O Low: Characterizes the upper range of voltage allowed on the device’s input/output pins while in a Logic Low state.
Current - Supply: This represents the maximum current to which a device will meet its given specifications. Exceeding this current may damage the device and/or other system components.
Voltage - Supply: Typically represented by a range, this indicates the low and high voltage limits which one can expect standard operation. Voltages outside this range may damage the device and other system components.
Meter Type: Indicates whether a metering IC is designed for measurement of single-or polyphase electrical services.
ProductExamples
| MFR PART # | ATM90E26-YU-R |
| DIGIKEY PART # | ATM90E26-YU-RTR-ND - Tape & Reel (TR) |
| MANUFACTURER | Microchip Technology |
| DESCRIPTION | Single Phase Meter IC 28-SSOP |
| MFR PART # | ADE7953ACPZ-RL |
| DIGIKEY PART # | 505-ADE7953ACPZ-RLTR-ND - Tape & Reel (TR) |
| MANUFACTURER | Analog Devices Inc. |
| DESCRIPTION | Single Phase Meter IC 28-LFCSP-WQ (5x5) |
| MFR PART # | CS5467-ISZ |
| DIGIKEY PART # | 598-CS5467-ISZ-ND |
| MANUFACTURER | Cirrus Logic Inc. |
| MFR PART # | STPM32TR |
| DIGIKEY PART # | 497-15634-2-ND - Tape & Reel (TR) |
| MANUFACTURER | STMicroelectronics |
| DESCRIPTION | 2 x Single Phase Meter IC 24-QFN (4x4) |
MediaLinks
Videos
Smart Metering Overview
Energy Metering
Articles
AFE ICs Simplify High-Precision Energy-Metering
Embedded Design Requirements for Smart Metering Systems
Highly Integrated Solutions for Embedded Power Meter Designs
ICs Offer Options for Apparent Power Measurement
Integrated Devices for IoT Energy Measurement
Product Training Modules
MSP430 - Metering-Energy Monitoring Apps - TI
