This Product Selection Guide contains information to help select products in the Arrays, Edge Type, Mezzanine (Board to Board) category on DigiKey.com
Connectors of this type have contacts arranged in linear rows and an outline which is generally rectangular, rather than circular. They are used for creating pluggable connections directly between printed circuit boards without use of wire or cable, and can provide a large number of electrical connections in a relatively small space. For this reason they are commonly used to connect components of space-constrained systems.
SelectionCharacteristics
Connector Type: Indicates the style and configuration of the device.
Number of Positions: Indicates the number of distinct conductors presented at a connector’s mating interface and the number of electrical contact points present within a connector.
Pitch: Indicates the center-to-center spacing between adjacent pins.
Number of Rows: Indicates how many rows the connector has.
Features: These are different capabilities or properties of the device such as board guide, ground pin, or shutter.
Contact Finish: Indicates the finish/plating material applied to the contacts of the device.
Contact Finish Thickness: Indicates the thickness of the finish/plating material applied to the contacts of a device.
Mated Stacking Heights: The distance between mounting surfaces of a connector and its complement when mated. Applicable primarily to connectors used between parallel surfaces.
Height Above Board: Indicates how far the device will extend above the surface to which it has been attached.
ProductExamples
| MFR PART # | IT14-688S-BGA-2.5H |
| DIGIKEY PART # | 26-IT14-688S-BGA-2.5HTR-ND - Tape & Reel (TR) |
| MANUFACTURER | Hirose Electric Co Ltd |
| DESCRIPTION | 688 Position Connector High Density Array, Female Surface Mount Tin |
| MFR PART # | 5050661222 |
| DIGIKEY PART # | 900-5050661222TR-ND - Tape & Reel (TR) |
| MANUFACTURER | Molex |
| DESCRIPTION | 12 Position Connector Receptacle, Center Strip Contacts Surface Mount Gold |
| MFR PART # | 10132797-011100LF |
| DIGIKEY PART # | 609-5020-2-ND - Tape & Reel (TR) |
| MANUFACTURER | Amphenol ICC (FCI) |
| DESCRIPTION | 10 Position Connector Plug, Outer Shroud Contacts Surface Mount Gold |
| MFR PART # | 10132798-012100LF |
| DIGIKEY PART # | 609-5027-2-ND - Tape & Reel (TR) |
| DESCRIPTION | 10 Position Connector Receptacle, Center Strip Contacts Surface Mount Gold |
MediaLinks
Videos
Hirose ER8 Series Connectors – DigiKey Daily
Hirose BM20 Series Connectors – DigiKey Daily
Hirose FunctionMAX Board-to-Board Connectors – DigiKey Daily
Articles
Mezalok Connectors High-Reliability XMC Mezzanine Connector
Product Training Modules
IEEE 1386 Mezzanine Connector - Molex Connector Corporation
Blogs
Overcoming Design Conundrums with Mezzanine Connectors
TechForum
Multiple Stacked Height Ratings?
