This Product Selection Guide contains information to help select products in the Bobbins (Coil Formers), Mounts, Hardware category on DigiKey.com
Products in this family are used in the construction of custom magnetic components such as transformers, or for the assembly of such into an end application. In addition to bobbins that provide a surface onto which the desired number of windings for a device can be wound, mounting and assembly hardware such as retaining clips/clamps, insulating washers, adjustment screws, and others are also included. Specifically excluded from this product family are the magnetic core components and wire typically used for the construction of magnetic components; these items are catalogued separately.
SelectionCharacteristics
Accessory Type: The type, style, or nature of the accessory.
ProductExamples
| MFR PART # | B66302D1008T002 |
| DIGIKEY PART # | B66302D1008T002-ND |
| MANUFACTURER | EPCOS - TDK Electronics |
| DESCRIPTION | BOBBIN COIL FORMER E 8.8 |
| MFR PART # | B65545B0009X000 |
| DIGIKEY PART # | 495-5134-ND |
| DESCRIPTION | YOKE P 14 X 8 |
| MFR PART # | CPHS-EP13-2S-10P-Z |
| DIGIKEY PART # | 1779-1325-ND |
| MANUFACTURER | Ferroxcube |
| DESCRIPTION | COIL FORMER HORIZONTAL SMD |
