May need your help to check any item from EPCOS or any brand has coil former which similar with Ferroxcube P/N: CP-P26/16-1S
Please provide the part number for my reference.
But, there is a problem is the coil former is higher than the ferrite core which has 5.8mm high.
So, I need a coil former with high 5.8mm to fit as same height with the ferrite core and the rest of spec details are same as CP-P26/16-1S
