Lenses
This Product Selection Guide contains information to help select products in the Lenses category on DigiKey.com
Lenses are clear or diffused surfaces used to provide diffusion of light emitted from a lamp or LED source. Lens colors are amber, black, blue, clear, frosted, green, ivory, orange, red, white, and yellow with the number of LEDs per lens ranging from 1 to 39. Lens styles are hourglass, irregular, rectangle, round, square, strip, and wedge.
SelectionCharacteristics
Type: Defines what kind of lens the part is.
Color: Indicates what color the lens is.
Number of LEDs: Indicates how many LEDs the lens is designed to fit.
Lens Style: Characterizes the shape of a device’s optical emitting surface.
Lens Size: Defines the overall dimension of the lens.
Lens Transparency: Describes the dispersion characteristics of a device’s lens.
Optical Pattern: Provides a basic description of how a lens shapes light emitted from a compatible emitter.
Viewing Angle: Indicates the angle of light emitted from the LED(s).
For Use With/Related Manufacturer: Defines other part types, numbers, or series with which this product is designed to be used.
Material: Indicates the material used for the lens.
ProductExamples
MFR PART # CMC_321_YTP
DIGI-KEY PART # CMC_321_YTP-ND
MANUFACTURER Visual Communications Company - VCC
DESCRIPTION LENS YELLOW PANEL MOUNT SNAP-IN
DATASHEET Click Here
MFR PART # CA11663_HEIDI-RS
DIGI-KEY PART # 711-1323-ND
MANUFACTURER Ledil
DESCRIPTION LENS CLR 6-12DEG SPOT ADH TAPE
MFR PART # C14729_HB-2X2-RS-PC
DIGI-KEY PART # 711-2884-ND
MANUFACTURER Ledil
DESCRIPTION LENS CLEAR 13DEG/14DEG SPOT
If you have any general questions on the specifications for selecting Lenses, please reply using the button below. If you have questions on specific Lenses please post those questions in the Optoelectronics category.
