This Product Selection Guide contains information to help select products in the Display Bezels, Lenses category on DigiKey.com
Display Bezels and Lenses are used to hold and define another device in a panel. The bezel is a frame that holds the lens in place on an LCD or LED display. The characteristics are type, for use with, color, and size/dimension with the types being bezel, bezel with lens, LED light value, and lens. The color of the lens is black, black/clear lens, black/green lens, black/red lens, black/smoke lens, clear lens, green lens, red lens, silver/clear lens, smoke lens, and white.
SelectionCharacteristics
Color: The dominant color of the device and/or lens.
Size/Dimension: The physical dimensions of the device. Typically length X width.
ProductExamples
| MFR PART # | 5001-200103 |
| DIGIKEY PART # | MGR1618-ND |
| MANUFACTURER | Storm Interface |
| DESCRIPTION | BEZEL SILVER W/CLEAR LENS |
| MFR PART # | 6302060 |
| DIGIKEY PART # | PRD250LPG-ND |
| MANUFACTURER | PRD Plastics |
| DESCRIPTION | LED DISPLAY BEZEL BLK W/GRN LENS |
| MFR PART # | EA 017-17UKE |
| DIGIKEY PART # | 1481-1003-ND |
| MANUFACTURER | Display Visions |
| DESCRIPTION | LCD DISPLAY BEZEL BLACK |
MediaLinks
Videos
Videos on Lenses
Articles
Choosing Lenses to Make the Most of LED Lumens
More Articles on Lenses
Product Training Modules
Aspherical Glass Lenses - Panasonic
Blogs
Blogs on Lenses
TechForum
LED Lens Color Vs. LED Lens Transparency
More TechForum posts on Lenses
