This Product Selection Guide contains information to help select products in the Magnetic Sensors - Switches (Solid State) category on DigiKey.com
Products in this family use solid-state technology for detecting the presence of a magnetic field in excess of some specific magnitude and/or sign, and provide a two-state output indicating the presence or absence of such a field. They are distinct from reed switches, which provide a similar function through the use of moving mechanical parts, as well as from linear or compass-type solid-state devices which provide a variable output indicative of the strength and/or orientation of an applied magnetic field.
SelectionCharacteristics
Specifications to determine which magnetic switch is right for your application.
Function: Identifies what type of switch it is, such as bipolar, omnipolar, etc.
Technology: How the circuit is setup to function, such as hall effect, magnetoresistive, etc.
Polarization: Identifies the polarity of the magnet.
Sensing Range: Physical distance between the trip and release points.
Test Condition: The temperature or range of temperatures the manufacturer tested the switch in.
Voltage - Supply: Typically represented by a range, this indicates the low and high voltage limits which one can expect standard operation. Voltages outside this range may damage the device and other system components.
Current - Supply (Max): This represents the maximum current to which a device will meet its given specifications. Exceeding this current may damage the device and/or other system components.
Current - Output (Max): The maximum amount of current that can be output by the device.
Output Type: Indicates the type of electrical signal the device provides, such as digital, analog voltage, etc.
Features: These are different capabilities or properties of the device such as amplified output, programmable, sleep mode, etc.
Package/Case: Indicates the type of protective case used on an electronic component to allow easy handling, installation, and protection. This selection was determined to be the closest industry standard applicable to the suppliers device packaging. Typically it is best to check the actual dimensions from the datasheet rather than depend on this terminology when designing your circuit.
ProductExamples
| MFR PART # | AH1913-W-7 |
| DIGIKEY PART # | AH1913-W-7DITR-ND - Tape & Reel (TR) |
| MANUFACTURER | Diodes Incorporated |
| DESCRIPTION | Digital Switch Omnipolar Switch Push-Pull Hall Effect SC-59-3 |
| MFR PART # | MLX92213ELD-AAA-000-RE |
| DIGIKEY PART # | MLX92213ELD-AAA-000-RETR-ND - Tape & Reel (TR) |
| MANUFACTURER | Melexis Technologies NV |
| DESCRIPTION | MAGNETIC SWITCH LATCH 6UTQFN |
| MFR PART # | SS41 |
| DIGIKEY PART # | 480-1999-ND |
| MANUFACTURER | Honeywell Sensing and Productivity Solutions |
| DESCRIPTION | Digital Switch Bipolar Switch Open Collector Hall Effect Radial Lead |
| MFR PART # | SNG-SPRC-002 |
| DIGIKEY PART # | 480-SNG-SPRC-002-ND |
| DESCRIPTION | Digital Switch Unipolar Switch Open Collector Hall Effect |
| MFR PART # | SNDH-H3L-G01 |
| DIGIKEY PART # | 480-5406-ND |
| DESCRIPTION | Digital Switch Special Purpose Open Collector Hall Effect Probe |
MediaLinks
Videos
How Does the Hall Effect Work? - Another Teaching Moment
Jump start your Hall-effect sensor expertise
Videos on Magnetic Switches
Articles
Micropower Hall-Effect Sensor ICs for Mobile Apps
Switch Your Switch | DigiKey
Articles on Solid State Switches
Product Training Modules
Magnetoresistive Sensor ICs, Nanopower Series- Honeywell
Blogs
Hall Effect Sensor Basics | DigiKey
TechForum
Magnetoresistive vs. Hall Effect in Sensor Applications
Hall Effect vs Reed Sensors
