This Product Selection Guide contains information to help select products in the Socket Accessories category on DigiKey.com
Sockets provide for repeated insertion, removal, substitution and replacement of Integrated Circuits (ICs) and transistors in a circuit. Socket accessories provide extra protection, additional capability, and identification options such as actuation mechanisms, back plates, caps and covers, clamps, carriers, contacts, labels, plugs, screws, and shorting plugs.
SelectionCharacteristics
Accessory Type: The type, style, or nature of the accessory.
Number of Pins: Indicates the number of leads present on components with which a product is designed for use.
Body Material: Indicates the material composition of the body of the device.
Body Finish: Indicates the finish/plating material applied to the body of the device.
Color: The dominant color of the device.
Features: These are different capabilities or properties of the device such as hardware, cover, or plates.
ProductExamples
| MFR PART # | 2-2330551-1 |
| DIGIKEY PART # | 17-2-2330551-1-ND |
| MANUFACTURER | TE Connectivity AMP Connectors |
| DESCRIPTION | Connector Backplate For LGA 4189 Sockets |
| MFR PART # | 2-2330552-2 |
| DIGIKEY PART # | 17-2-2330552-2-ND |
| DESCRIPTION | Connector Carrier For LGA 4189 Sockets |
| MFR PART # | 4634 |
| DIGIKEY PART # | 36-4634-ND |
| MANUFACTURER | Keystone Electronics |
| DESCRIPTION | Connector Cover For TO-3 |
