This Product Selection Guide contains information to help select products in the Socket Adapters category on DigiKey.com
Sockets provide for repeated insertion, removal, substitution and replacement of Integrated Circuits (ICs) and transistors in a circuit. Socket adapters allow the use of ICs and transistors of one package type to be used in place of another package type such as adapting an eight-pin DIP package to a JEDEC socket package. Popular surface mount and through-hole packages may be converted to DIP, JEDEC, PGA, PLCC, QFP, SOIC and SOWIC.
SelectionCharacteristics
Convert From (Adapter End): Indicates the style and configuration of the device being converted from.
Convert To (Adapter End): Indicates the style and configuration of the device being converted to.
Number of Pins: Indicates the number of leads present on components with which a product is designed for use.
Pitch - Mating: The nominal center distance between adjacent contacts on the side of a device that is intended to connect to a complementary connector or device package.
Contact Finish - Mating: Indicates the material with which the mating portion of a product is plated or finished.
Termination: Selection of termination style used to connect the device to a system, such as solder or wire wrap.
Pitch - Post: The distance between contacts on the side of a socket that typically interfaces with a circuit board.
Contact Finish - Post: Indicates the surface finish/plating material present on the portion of a product intended for permanent attachment in an application.
Housing Material: Indicates the material composition of the housing of the device.
Board Material: Indicates the material composition of the board on the device.
ProductExamples
| MFR PART # | 28-653000-10 |
| DIGIKEY PART # | A326-ND |
| MANUFACTURER | Aries Electronics |
| DESCRIPTION | IC Socket Adapter PLCC To DIP, 0.6" (15.24mm) Row Spacing Through Hole |
| MFR PART # | 216-3340-09-0602J |
| DIGIKEY PART # | 3M1601-ND |
| MANUFACTURER | 3M |
| DESCRIPTION | IC Socket Adapter DIP, 0.3" (7.62mm) Row Spacing To DIP, 0.3" (7.62mm) Row Spacing Through Hole |
| MFR PART # | 1109523 |
| DIGIKEY PART # | A330-ND |
| DESCRIPTION | IC Socket Adapter DIP, 0.3" (7.62mm) Row Spacing To JEDEC Through Hole |
| MFR PART # | LCQT-QFP0.5-60 |
| DIGIKEY PART # | A872AR-ND |
| DESCRIPTION | IC Socket Adapter Multiple Packages To QFP Through Hole |
