This Product Selection Guide contains information to help select products in the Sensor Interface – Junction Blocks category on DigiKey.com
Junction Blocks for Sensor Interface applications are interconnect devices used to combine signals from multiple sensors or actuators having individual cabling requirements into a shared cabling system that is better suited for carrying signals over long distances by virtue of eliminating unnecessary conductors and electrical insulation material.
SelectionCharacteristics
Specifications to determine which junction block is right for your application.
Accessory Type: The type, style, or nature of the accessory.
Color: The dominant color of the device.
Features: These are different capabilities of the device, such as dust tight, waterproof, etc.
Material: Indicates the material composition of the device.
Shell Size - Insert: Describes the size of a connector or component thereof in terms of the size of the contact-bearing insert with which a product is compatible. Insert size designations are derived from various industry and military standards.
ProductExamples
| MFR PART # | 1437258 |
| DIGIKEY PART # | 277-13185-ND |
| MANUFACTURER | Phoenix Contact |
| DESCRIPTION | SENSOR ACTUATOR BOX 4SLOT 5POS |
| MFR PART # | 1760060000 |
| DIGIKEY PART # | 281-6557-ND |
| MANUFACTURER | Weidmüller |
| DESCRIPTION | CONN SAI 8 M IDC HARAX 3POS |
| MFR PART # | 1202480520 |
| DIGIKEY PART # | WM15744-ND |
| MANUFACTURER | Molex |
| DESCRIPTION | MPIS M12 SAFETY NOS 5P 4PT AC FE |
| MFR PART # | 0980 ESL 393-121 |
| DIGIKEY PART # | 1794-1109-ND |
| MANUFACTURER | Lumberg Automation |
| DESCRIPTION | MULTIPROTOCOL M12 SENSOR BLOCK |
| MFR PART # | DRT2-MD32BV |
| DIGIKEY PART # | Z12051-ND |
| MANUFACTURER | Omron Automation and Safety |
| DESCRIPTION | 16IN 16OUT VERT MIL CONN NPN |
