This Product Selection Guide contains information to help select products in the Controllers - Accessories category on DigiKey.com
Products within the logic controller accessory family are ancillary to or supportive of the operation or use of a programmable logic controller. Among many other products are replacement memory backup batteries, programming adapters, expansion backplanes, carrying cases, programming software and license keys, interconnect terminal blocks, mounting brackets, option cards, programming tools, and others.
SelectionCharacteristics
Accessory Type: The type, style, or nature of the accessory.
Specifications: This selection indicates the attributes which expound on a product’s abilities but are not a standard attribute universal to this product family.
ProductExamples
| MFR PART # | AHACABH0-5A |
| DIGIKEY PART # | 2039-AHACABH0-5A-ND |
| MANUFACTURER | Delta Electronics/Industrial Automation |
| DESCRIPTION | Cable Assembly AH500 Series |
| MFR PART # | CS1W-BC103 |
| DIGIKEY PART # | Z8979-ND |
| MANUFACTURER | Omron Automation and Safety |
| DESCRIPTION | Backplane CS1 Series |
| MFR PART # | 88980162 |
| DIGIKEY PART # | 1464-1007-ND |
| MANUFACTURER | Crouzet |
| DESCRIPTION | Wireless Antenna Millenium 3 Series |
