This Product Selection Guide contains information to help select products in the DIN Rail Channel category on DigiKey.com
A DIN rail is a bracket of a standard type widely used for convenient mounting of circuit breakers and industrial control devices inside equipment racks and control panel enclosures. The term ‘DIN’ is derived from the original specifications published by Deutsches Institut für Normung (DIN) in Germany. Aluminum, copper, steel, plastic, and stainless steel DIN rails come in slotted or unslotted, top hat (O), C, and G section profiles.
SelectionCharacteristics
Type: Indicates what shape the DIN rail is.
Slotted/Unslotted: Indicates whether or not DIN rail material is fabricated with mounting slots along its length.
Size: Indicates the width and height of the DIN rail.
Length: Indicates the length of the DIN rail.
Thickness: Indicates the thickness of the material from which the DIN rail is fabricated.
Material: Indicates the material composition of the DIN rail.
Plating: Indicates the finish/plating material applied to the DIN rail.
ProductExamples
| MFR PART # | 514510000 |
| DIGIKEY PART # | 281-1534-ND |
| MANUFACTURER | Weidmüller |
| DESCRIPTION | DIN RAIL 35MMX7.5MM SLOTTED 1M |
| MFR PART # | 801681 |
| DIGIKEY PART # | 277-7262-ND |
| MANUFACTURER | Phoenix Contact |
| DESCRIPTION | DIN RAIL 35MMX7.5MM UNSLOT 2M |
| MFR PART # | 514300000 |
| DIGIKEY PART # | 281-5398-ND |
| DESCRIPTION | DIN RAIL 35MMX15MM UNSLOT PVC 2M |
MediaLinks
Videos
Din Rail Options | DigiKey
