This Product Selection Guide contains information to help select products in the Power Entry Connector Accessories category on DigiKey.com
This category is Accessories for Power Entry connectors.
SelectionCharacteristics
Accessory Type: This describes the type of accessory.
Region Utilized: Indicates the region(s) of the globe to which a product is adapted for use by virtue of the connector style incorporated and/or voltage levels accommodated.
ProductExamples
| MFR PART # | 859.0047 |
| DIGIKEY PART # | 486-1959-ND |
| MANUFACTURER | SCHURTER Inc. |
| DESCRIPTION | Connector Boot, Insulating For Power Entry Inlets and Outlets |
| MFR PART # | 730-00/05 |
| DIGIKEY PART # | Q266-ND |
| MANUFACTURER | Qualtek |
| DESCRIPTION | Connector Retainer Clip For AC Power Plug Assembly |
| MFR PART # | 4301.1407 |
| DIGIKEY PART # | 486-1342-ND |
| DESCRIPTION | Connector Fuse Drawer For DD11, DD12, DD21, DD22, KEA-Print, KFA, KMF |
| MFR PART # | P002-000 |
| DIGIKEY PART # | TL2397-ND |
| MANUFACTURER | Tripp Lite |
| DESCRIPTION | Connector Adapter For Power Cord Receptacles |
