This Product Selection Guide contains information to help select products in the DSL Filters category on DigiKey.com
A DSL filter is an analog low-pass filter installed between analog devices (such as telephones or analog modems) and a plain old telephone service (POTS) line. The DSL filter prevents interference between such devices and a digital subscriber line (DSL) service connected to the same line. Without DSL filters, signals or echoes from analog devices at the top of their frequency range which can reduce performance and create connection problems with DSL service, while those from the DSL service at the bottom of its range can cause line noise and other problems for analog devices.
SelectionCharacteristics
Input Type: Indicates the number of inputs.
Output Type: Indicates the number and type of outputs.
ProductExamples
| MFR PART # | Z-A431PJ31X-A |
| DIGIKEY PART # | 553-1497-ND |
| MANUFACTURER | Pulse Electronics |
| DESCRIPTION | FILTER DSL ALARM PANEL SINGLE |
| MFR PART # | Z-300TJ |
| DIGIKEY PART # | 553-1426-ND |
| DESCRIPTION | FILTER DSL DUAL-JACK WHITE |
