This Product Selection Guide contains information to help select products in the Magnets - Sensor Matched Magnets category on DigiKey.com
Sensor-Matched Magnet products are magnets that are specifically indicated for use with one or more magnetic sensor products, and which often incorporate some sort of overmolding or packaging to facilitate mechanical mounting in an end application. Though most magnet-based sensor systems can be used with any magnet having suitable characteristics, availability of matched magnets allows sensor manufacturers to describe the behavior of their products in terms of a magnet of known characteristics.
SelectionCharacteristics
Specifications to determine which sensor matched magnet is right for your application.
Housing Material: Indicates the material composition of the hosing of the device.
Material - Magnet: Indicates the material composition of the magnet.
Package/Case: Indicates the type of protective case used on an electronic component to allow easy handling, installation, and protection. This selection was determined to be the closest industry standard applicable to the suppliers device packaging. Typically it is best to check the actual dimensions from the datasheet rather than depend on this terminology when designing your circuit.
Size: The physical dimensions of the magnet. Typically diameter and length, or length, width, and height.
ProductExamples
| MFR PART # | 57135-000 |
| DIGIKEY PART # | 57135-000-ND |
| MANUFACTURER | Littelfuse Inc. |
| DESCRIPTION | 59135 Magnet 1.125" L x 0.259" W x 0.750" H (28.6mm x 6.40mm x 19.0mm) Plastic Housin |
| MFR PART # | CTI302M |
| DIGIKEY PART # | 1835-CTI302M-ND |
| MANUFACTURER | Comus International |
| DESCRIPTION | S1736 Magnet Nickel Plated Brass Housing |
| MFR PART # | CLSA2 |
| DIGIKEY PART # | 1864-1624-ND |
| MANUFACTURER | Carlo Gavazzi Inc. |
| DESCRIPTION | Magnet Plastic Housing |
| MFR PART # | M9105/K06 |
| DIGIKEY PART # | 1724-1551-ND |
| MANUFACTURER | Sensata-BEI Sensors |
| DESCRIPTION | ACW and TCW Sensors Magnet Housing |
| MFR PART # | M11/M8 |
| DIGIKEY PART # | 374-1099-ND |
| MANUFACTURER | Standex-Meder Electronics |
| DESCRIPTION | MK11/M8 Magnet 0.315" Dia x 1.50" L (8.00mm x 38.0mm) Plastic Housing |
MediaLinks
Videos
Magnets for Sensor Systems
How to Orient Magnets Around Magnetic Sensors
Product Training Modules
Magnet Technology - Standex Electronics
TechForum
TechForum posts on Matched Magnets
