This Product Selection Guide contains information to help select products in the Insertion, Extraction category on DigiKey.com
Insertion, Extraction tool is a device used to place or remove a contact within a housing of a connector. The types are Adapter, Bench Press, Extraction tool, Index Slide, Insertion Guide Pin, Insertion Tool, and Termination Tool that are used for backplane connectors, Circular connectors, BNC connectors, Card Edge connectors, Coaxial RF connectors, D-sub connectors, Fiber Optic connectors, Heavy Duty Contacts, Photovoltaic contacts, Quick Connect Terminals, and Rectangular Contacts to name a few.
SelectionCharacteristics
Tool Type: Indicates the style and configuration of the device.
ProductExamples
| MFR PART # | U.FL-LP-N-2 |
| DIGIKEY PART # | H9159-ND |
| MANUFACTURER | Hirose Electric Co Ltd |
| DESCRIPTION | Extraction Tool For Coaxial, RF Connectors |
| MFR PART # | 11030043 |
| DIGIKEY PART # | WM9937-ND |
| MANUFACTURER | Molex |
| DESCRIPTION | Extraction Tool For Rectangular Contacts |
| MFR PART # | 59803-1 |
| DIGIKEY PART # | A9982-ND |
| MANUFACTURER | TE Application Tooling |
| DESCRIPTION | Insertion Tool For Rectangular Connectors |
| MFR PART # | U.FL-LP-IN |
| DIGIKEY PART # | H125226-ND |
| DESCRIPTION | Insertion/Extraction Tool For Coaxial, RF Connectors |
MediaLinks
Videos
Insertion and Removal Tools Overview
Molex - Terminal Housing Insertion and Extraction
Series 917X Standard IDC with Hand Insertion Tool
Jonard’s Flaring & Insertion Tool
ML-XT Extraction Video
TechForum
Forum posts on Insertion Tools
Forum posts on Extraction Tools
