Is there a de-pinning tool for the following Molex connector:
| DigiKey Part Number | WM16558-ND |
| Manufacturer | Molex |
| Manufacturer Product Number | 1501792040 |
| Description | CONN RCPT HSG 4POS 3.68MM |
Welcome to the Technical Forum. The part number for the extraction tool is WM9929-ND on this link: 0011030002 Molex | Tools | DigiKey
Generally we would need the contact terminal number to pick out the extraction or any tool. Though this extraction tool appears to work with the whole series.
The following link will have all information needed:
https://www.digikey.com/en/products/detail/molex/1501792040/7062986
I can pull the housing up on the website. Though the extraction tools are picked out by the contact terminal used. Though found the extraction or de-pinning tool above. This is what you would need to extract the terminal out of the housing.
