This Product Selection Guide contains information to help select products in the V-F and F-V Converters category on DigiKey.com
Voltage-to-frequency conversion integrated circuits (ICs) monitor an input voltage and output a ratiometric frequency for applications such as automotive sensing, battery monitoring, analog-to-digital conversion, and signal isolation. Frequency-to-voltage conversion ICs output an analog voltage ratiometric to an input frequency for instrumentation and metering such as speed sensing, tachometers, cruise control, and touch switches.
SelectionCharacteristics
Type: Defines the direction of conversion for the device.
Frequency - Max: The maximum frequency the device can convert from or to.
Full Scale: Indicates the change in electrical properties for a given change in temperature. The device is usually specified at 25 degrees Celsius as a baseline temperature.
Linearity: Characterizes deviations of a device’s transfer function from an ideal straight line.
Supplier Device Package: This is what the manufacturer calls the package of this device. They are manufacturer-specific. It is typically best to use the actual dimensions from the datasheets rather than to go by this terminology when designing your circuit.
ProductExamples
| MFR PART # | AD7740YRMZ-REEL7 |
| DIGIKEY PART # | AD7740YRMZ-REEL7TR-ND - Tape & Reel (TR) |
| MANUFACTURER | Analog Devices Inc. |
| DESCRIPTION | Voltage to Frequency Converter IC 1 MHz ±0.012% 8-MSOP |
| MFR PART # | TC9400CPD |
| DIGIKEY PART # | TC9400CPD-ND |
| MANUFACTURER | Microchip Technology |
| DESCRIPTION | Volt to Frequency and Frequency to Volt Converter IC 100 kHz ±0.05% 14-PDIP |
| MFR PART # | NJM4151D |
| DIGIKEY PART # | 2129-NJM4151D-ND |
| MANUFACTURER | Nisshinbo Micro Devices Inc. |
| DESCRIPTION | Volt to Frequency and Frequency to Volt Converter IC 100 kHz ±1% 8-DIP |
| MFR PART # | LM2907MX/NOPB |
| DIGIKEY PART # | LM2907MX/NOPBTR-ND - Tape & Reel (TR) |
| MANUFACTURER | Texas Instruments |
| DESCRIPTION | Frequency to Voltage Converter IC 10 kHz ±0.3% 14-SOIC |
