We often get people looking for different ways to convert one electrical signal, such as resistance, into another type of signal, such as voltage. Or converting one voltage or current to a different voltage or current. Our website can sometimes get very confusing and searching for converters does not bring these types of devices up.
These types of devices fall into our signal conditioners and isolators category.
Then just use the filters on that page to narrow down your options. This way you can select input type and range as well as output type and range as seen below.
Other filters will allow you to select isolation level, voltage supply level, manufacturer specific features, operating temperature and more.
Here are some examples from the category:
| MFR PART # | 857-809 |
| DIGI-KEY PART # | 2946-857-809-ND |
| MANUFACTURER | WAGO Corporation |
| DESCRIPTION | POTENTIOMETER SIGNAL CONDITIONER |
| MFR PART # | 1453210000 |
| DIGI-KEY PART # | 281-3391-ND |
| MANUFACTURER | Weidmüller |
| DESCRIPTION | ACT20P-UI-AO-DO-LP-S |
| MFR PART # | SC420I |
| DIGI-KEY PART # | 725-1611-ND |
| MANUFACTURER | Sensata-Cynergy3 |
| DESCRIPTION | ISOLATOR LOOP PWR DIN MNT 1KV IS |
| MFR PART # | 2810078 |
| DIGI-KEY PART # | 277-9326-ND |
| MANUFACTURER | Phoenix Contact |
| DESCRIPTION | 3-WAY ISOLATING AMP 4-20MA |
