This Product Selection Guide contains information to help select products in the Focus Lenses category on DigiKey.com
Laser Optic Focus Lenses are the final piece in a laser system and are used to focus the beam to a specific focal length.
SelectionCharacteristics
Wavelength: Indicates the wavelength(s) of light the device is designed for use with.
Lens Material: Indicates the material from which a lens is made.
Focal Length: The distance between the lens and the point where parallel light rays converge to a single focal point.
| MFR PART # | 4401-420-000-21 |
| DIGIKEY PART # | 1601-4401-420-000-21-ND |
| MANUFACTURER | Excelitas Technologies |
| DESCRIPTION | FOCUS-RONAR; F=122MM/WL=1064+532 |
| MFR PART # | 4401-490-000-20 |
| DIGIKEY PART # | 1601-4401-490-000-20-ND |
| DESCRIPTION | FOCUS-RONAR, F=90MM/WL=1064+532N |
| MFR PART # | 4401-486-000-20 |
| DIGIKEY PART # | 1601-4401-486-000-20-ND |
| DESCRIPTION | FOCUS-RONAR; F=77MM/WL=1064+532N |
