This Product Selection Guide contains information to help select products in the Delay Lines category on DigiKey.com
Products in the clock delay line family are digital devices used to introduce a time delay into a digital signal, such that signal transitions presented to a device’s input are replicated at the output after some known period of time. They are often used in high-speed digital systems to correct or compensate for variations in signal propagation times between different signal paths. Devices are available to generate delays of fixed, selectable, or variable duration.
SelectionCharacteristics
Number of Taps/Steps: The number of points along the delay line where a signal can be accessed; the granularity of delay length adjustment.
Function: Describes the main function or usage of the circuit.
Delay to 1st Tap: The nominal time delay from input to the first (shortest delay) output; the minimum time delay the device can produce.
Tap Increment: The nominal difference in delay length between functionally-adjacent outputs from the delay line.
Available Total Delays: End-to-end delay line length (range for variable-delay devices)
Number of Independent Delays: Indicates the number of independent delays per device function.
Voltage - Supply: Typically represented by a range, this indicates the low and high voltage limits which one can expect standard operation. Voltages outside this range may damage the device and other system components.
Package / Case: Indicates the type of protective case used on an electronic component to allow easy handling, installation, and protection. This selection was determined to be the closest industry standard applicable to the suppliers device packaging. Typically it is best to check the actual dimensions from the datasheet rather than depend on this terminology when designing your circuit.
ProductExamples
| MFR PART # | LTC6994IDCB-1#TRMPBF |
| DIGIKEY PART # | LTC6994IDCB-1#TRMPBFTR-ND - Tape & Reel (TR) |
| MANUFACTURER | Analog Devices Inc. |
| DESCRIPTION | Delay Line IC Programmable 8 Tap 1µs ~ 33.6s 6-WFDFN Exposed Pad |
| MFR PART # | NB6L295MNG |
| DIGIKEY PART # | NB6L295MNGOS-ND |
| MANUFACTURER | onsemi |
| DESCRIPTION | Delay Line IC Multiple, Programmable 512 Tap 3.2ns ~ 8.5ns, 6.2ns ~ 16.6ns 24-VFQFN Exposed Pad |
| MFR PART # | SY55856UHG |
| DIGIKEY PART # | 576-2046-ND |
| MANUFACTURER | Microchip Technology |
| DESCRIPTION | Delay Line IC Multiple, NonProgrammable 7 Tap 350ps 32-TQFP Exposed Pad |
MediaLinks
Videos
PCI Express (PCIe) Clock Generators by IDT
Clock
Articles
Minimizing Jitter/Phase Noise in Clock-Distribution Topology is Critical to Wireless Performance
Clock
Product Training Modules
Si533x/5x Any-Rate Clock Generators and Clock Buffers
Clock
TechForum
Clock
