I have hard time to get BBBw into uart0 console booting mode. It was working by the following sequence:
Connect console UART0 to a host ternimal
Press and Hold boot button,
Plug in power ( I plugged in the micro usb for powering up the BBB)
I am expecting ‘CCC…’ to be shown on the host terminal window
I tried several units, and waited over 2 minute. ‘CCC…’ are not displayed.
(Maybe timeout is longer than 2 minutes?
Thank you, Robert. It is very quick to switch to usb boot mode. But the cycle time from uart0 to usb mode takes very long time. (Or from uart0 to next uart0 mode takes long time). I didn’t measure, it is more than 2 minutes, probably.
I am working on our production board first time. Currently micro usb port is not working, so I trying to get uart0 going, which can confirm chip is up running ok. But I found that the MLO is successfully downloaded, and it fails to download u-boot.img (the second stage u-boot file, using YMODEM). I tried tera term. It just hungs when it trying to download u-boot.img. Later, I tried picocom. It seems to me that uart0 port is working ok under ROM, but not under the MLO. (posted error messages):
$ sx -vv u-boot.img
Sending u-boot.img, 6056 blocks: Give your local XMODEM receive command now.
Xmodem sectors/kbytes sent: 0/ 0kRetry 0: Timeout on sector ACK
Retry 0: Retry Count Exceeded
Transfer incomplete
*** exit status: 128 ***
FATAL: read zero bytes from port
term_exitfunc: reset failed for dev UNKNOWN: Input/output error
I am wandering the clock frequency is set to 24MHZ is right?
SYSBOOT[15:14]
00 = 19.2 MHz
01 = 24 MHz
10 = 25 MHz
11 = 26 MHz
Or what else is needed at hardware configuration level to be functional for MLO?
On the other hand, at the ‘ccc…’ is continuously displayed with/without Boot Button is pressed. The NDIS driver is never initiated. Certainly it is related to our hardware. And it is our production board. Your input and suggestion are greatly appreciated.
Sorry, i’ve never done a usart0 based boot method on the AM335x. I know you need to reconfigure the MLO/u-boot.img build of u-boot. At one time there was uart specific configs for am335x_evm, but i don’t think those unique config’s are in the latest branches anymore.
Thank you for your confirmation of frequency and input.
I am working on software. There is usb issue with the first board. The uart0 boot method is to identify bare board issues. Eventually, usb will be used.
Best Regards,
From TeraTerm Menu click “ File -> Transfer -> Kermit -> Send ”.
Select the 1st stage u-boot image “ MLO ” and click “OPEN” button
But many other places, to download
u-boot-spl.bin instead of MLO
AND
use Kermit for both instead of (XModem for 1st Stage and YModem for 2nd Stage)
When I download MLO, the u-boot.img will not start to download.
When I download u-boot-spl.bin, the u-boot.img will start, but it stops , got an timeout ACK
In picocom, Press CTRL+A; CTRL+S; transfer u-boot-spl.bin from u-boot/spl/
Plug in/power board, and wait for transfer to complete:
Press CTRL+A; CTRL+S; transfer u-boot.img
picocom -b 115200 /dev/ttyUSB0 --send-cmd "sx -vv"
picocom v3.1
port is : /dev/ttyUSB0
flowcontrol : none
baudrate is : 115200
parity is : none
databits are : 8
stopbits are : 1
escape is : C-a
local echo is : no
noinit is : no
noreset is : no
hangup is : no
nolock is : no
send_cmd is : sx -vv
receive_cmd is : rz -vv -E
imap is :
omap is :
emap is : crcrlf,delbs,
logfile is : none
initstring : none
exit_after is : not set
exit is : no
Type [C-a] [C-h] to see available commands
Terminal ready
*** file: u-boot-spl.bin
$ sx -vv u-boot-spl.bin
Sending u-boot-spl.bin, 848 blocks: Give your local XMODEM receive command now.
Bytes Sent: 108672 BPS:6882
Transfer complete
*** exit status: 0 ***
U-Boot SPL 2020.10-rc3 (Sep 02 2020 - 12:24:07 -0500)
Trying to boot from UART
CC
*** file: u-boot.img
$ sx -vv u-boot.img
Sending u-boot.img, 6107 blocks: Give your local XMODEM receive command now.
Xmodem sectors/kbytes sent: 0/ 0kRetry 0: NAK on sector
Bytes Sent: 781824 BPS:7632
Transfer complete
xyzModem - CRC mode, 6109(SOH)/0(STX)/0(CAN) packets, 4 retries
Loaded 781724 bytes
U-Boot 2020.10-rc3 (Sep 02 2020 - 12:24:07 -0500)
CPU : AM335X-GP rev 2.1
Model: TI AM335x BeagleBone Black
DRAM: 512 MiB
WDT: Started with servicing (60s timeout)
NAND: 0 MiB
MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1
Loading Environment from FAT... <ethaddr> not set. Validating first E-fuse MAC
Net: eth2: ethernet@4a100000, eth3: usb_ether
Hit any key to stop autoboot: 0
=> version
arm-linux-gnueabihf-gcc (Linaro GCC 6.5-2018.12) 6.5.0
GNU ld (Linaro_Binutils-2018.12) 2.27.0.20161229
I have a question related to the u-boot-spl.bin (MLO) and u-boot.img:
There is code to read/write EEPROM in the U-boot. But images are splitted into the above two images. So, EEPROM read/write is compiled into which of the above image. I had EEPROM written through the u-boot, but don’t know the writing is on which part.
So u-boot-spl.bin is loaded in SRAM, it initiates the base interfaces (usart/i2c/mmc/etc), reads the eeprom, initializes the rest and DDR. Then it “loads” u-boot.img from somewhere (usart/usb/mmc/etc…) and starts u-boot from DDR memory.
If you’d like to write the eeprom, do it in u-boot (u-boot.img)… (GND the test point…)
I already have u-boot to register EEPROM. It works with usb. I am wandering it doesn’t load u-boot.img (on our production boards) that is related EEPROM. The same sets of u-boot images, loads both files on BBBw.
Although the u-boot-spl.bin and u-boot.img may not been built for uart boot mode, BUT
With BBBw dev board, when the first u-boot-spl.bin is loaded, it displays:
CCC…
WIth our own production boards, when downloaded the same above u-boot-spl.bin, it doesn’t display “Trying to boot from UART…”, then the u-boot.img is stuck during download.
the above message is from the function
boot_from_devices ()
loader = spl_ll_find_loader(spl_boot_list[i]);
#if defined(CONFIG_SPL_SERIAL_SUPPORT) && defined(CONFIG_SPL_LIBCOMMON_SUPPORT)
if (loader)
printf(“Trying to boot from %s\n”, loader->name);
else
puts(“SPL: Unsupported Boot Device!\n”); #endif
if (loader && !spl_load_image(spl_image, loader))
return 0;
I rebuilt 2018-07 version of u-boot with am335x_evm_defconfig.
I expected to be able to download and run even without EEPROM is set, and break it bootloader shell. The purpose of that is helping hardware debugging usb0 and with some degree of board testing.
But the downloading of u-boot.img was stopped at 509 packets, 502192 bytes (77.7%) on BBBw ( I think BBBw has EEPROM set).
For our production board, it stops, too. (see screen dump):
I confirmed that the first stage has r/w EEPROM functions. Even it aborts, it will update EEPROM.
U-Boot SPL 2018.07-dirty (Aug 12 2020 - 13:46:14 -0400)
SPL: failed to boot from all boot devices
ERROR ### Please RESET the board
//======== EEPROM has been set (with my customized code).
I guess we have usb0 issue. But I cannot find any good version for BBBw to be loaded through uart and break into u-boot. The bootloader has many drivers built-in. It will be very helpful to use bootloader for board testing.
