Beagle Bone Black Boot Issue
My Beagle Bone Black that was working just fine now refuses to boot.
After power is applied using the barrel jack and 5V supply, the PWR led next to the barrel jack lights up, but nothing else does.
Up to this point, I had been trying to get the 7" NewHaven display working. I was going to through some of the other posts on this site. One of the posts mentioned that the eMMC might be interfering, so I followed those steps:
[[BeagleBone] Newhaven NHD-7.0CTP-CAPE] ([BeagleBone] Newhaven NHD-7.0CTP-CAPE)
Shortly after that (can’t remember if it was immediately, or several more boot/configuration attempts after that), that the device stopped booting at all.
Holding down S2 during power up doesn’t affect anything. Pressing S1 or S3 also does nothing.
With or without an SD card in the slot, the USER leds are always dark.
Any ideas?
@jeffdk,
Please re-test with this image flashed to a microSD, with no cape plugged in:
https://elinux.org/Beagleboard:BeagleBoneBlack_Debian#Stretch_IOT_Snapshot
Regards,
Thanks @RobertCNelson for the quick reply!
I did as you suggested, re-tested with the image flashed to a microSD, and no cape.
The results are unchanged, the board does not boot. No flashing of user lights to indicate access of the SD card. I tried both the microSD and eMMC flasher images.
Do I need to press the S2 button to select the boot options? I tried both with and without pressing the S2 switch.
Thanks again!
@jeffdk, you don’t need to hit the S2 button unless there is something in the eMMC blocking bootup.
Did you use https://www.balena.io/etcher/ when you wrote the image to the microSD card?
Regards,
Yes, I used the balena etcher software. It works great.
@jeffdk, i’d start the RMA process for this board, it seems to be having issues booting up with our beagleboard.org images.
Regards,
OK, thanks again for your help! I’ll go through the RMA process.
Jeff
One last question: Would connecting to the RS232 port header give us any useful information?
@jeffdk,
It might, but one of the first things that u-boot does is turn on one of the 4 other led’s…
So i’d expect some blinking lights.
Regards,
I connected to the BBB serial header this morning with PuTTY and a borrowed USB to 3.3V serial port. I’m getting a screen full of “C”! Can this BBB be brought back to life?
@jeffdk, that is expected… When the eMMC is blank, and no microSD is installed. The am335x’s bootrom transmit’s a C character over the uart attempting to boot over the serial port. So your board is at-least trying to boot from the eMMC.
Try another microSD card with: https://elinux.org/Beagleboard:BeagleBoneBlack_Debian#Stretch_IOT_Snapshot
Regards,
@RobertCNelson,
With the Stretch_IOT_Snapshot,eMMC flasher download, this is what I am getting now…
The following contains three boot attempts.
I also downloaded the U-Boot SPL (only the first two files: u-boot-spl.bin and u-boot.img) as shown in this video: https://www.youtube.com/watch?v=3y1LMNPoaJI. Files were downloaded from https://github.com/niekiran/EmbeddedLinuxBBB. Not much was happening in the way of booting before then. Or maybe I wasn’t holding the boot button long enough. Are these boot files generic enough for my purposes?
CCC
U-Boot SPL 2017.03-00270-g5cf618e (Mar 28 2017 - 17:14:21)
Trying to boot from UART
CCxyzModem - CRC mode, 1(SOH)/356(STX)/0(CAN) packets, 4 retries
Loaded 364100 bytes
U-Boot 2016.11-rc1 (Mar 29 2017 - 09:34:17 +0530)
I2C:   ready
DRAM:  512 MiB
MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
** First descriptor is NOT a primary desc on 1:1 **
*** Warning - bad CRC, using default environment
Net:   <ethaddr> not set. Validating first E-fuse MAC
cpsw, usb_ether
Press SPACE to abort autoboot in 2 seconds
Card did not respond to voltage select!
switch to partitions #0, OK
mmc1(part 0) is current device
** No partition table - mmc 1 **
SD/MMC found on device 1
Failed to mount ext2 filesystem...
** Unrecognized filesystem type **
## Error: "bootcmd_nand0" not defined
starting USB...
USB0:   Port not available.
U-Boot SPL 2019.04-00003-g2c51b9db63 (May 20 2019 - 13:06:46 -0500)
Trying to boot from MMC1
Loading Environment from EXT4... ** File not found /boot/uboot.env **
** Unable to read "/boot/uboot.env" from mmc0:1 **
U-Boot 2019.04-00003-g2c51b9db63 (May 20 2019 - 13:06:46 -0500), Build: jenkins-github_Bootloader-Builder-120
CPU  : AM335X-GP rev 2.1
I2C:   ready
DRAM:  512 MiB
No match for driver 'omap_hsmmc'
Some drivers were not found
Reset Source: Power-on reset has occurred.
RTC 32KCLK Source: External.
Board: BeagleBone Black
BeagleBone Black:
BeagleBone: cape eeprom: i2c_probe: 0x54:
BeagleBone: cape eeprom: i2c_probe: 0x55:
BeagleBone: cape eeprom: i2c_probe: 0x56:
BeagleBone: cape eeprom: i2c_probe: 0x57:
Net:   eth0: MII MODE
cpsw, usb_ether
board_name=[A335BNLT] ...
board_rev=[000C] ...
gpio: pin 56 (gpio 56) value is 0
gpio: pin 55 (gpio 55) value is 0
gpio: pin 54 (gpio 54) value is 0
gpio: pin 53 (gpio 53) value is 1
gpio: pin 54 (gpio 54) value is 1
Checking for: /uEnv.txt ...
Checking for: /boot.scr ...
Checking for: /boot/boot.scr ...
Checking for: /boot/uEnv.txt ...
starting USB...
I2C:   ready
DRAM:  512 MiB
BeagleBone Black:
Net:   eth0: MII MODE
cpsw, usb_ether
mmc0 is current device
SD/MMC found on device 0
Scanning mmc 0:1...
gpio: pin 55 (gpio 55) value is 1
mmc_read_data: timedout waiting for status!
omap_hsmmc_send_cmd: timedout waiting on cmd inhibit to clear
 ** fs_devread read error **
## Info: input data size = 902 = 0x386
Loaded environment from /boot/uEnv.txt
Checking if uname_r is set in /boot/uEnv.txt...
** Can't read partition table on 0:0 **
** Invalid partition 2 **
** Invalid partition 3 **
** Invalid partition 4 **
** Invalid partition 5 **
** Invalid partition 6 **
** Invalid partition 7 **
starting USB...
spl: mmc init failed with error: -95
SPL: failed to boot from all boot devices
### ERROR ### Please RESET the board ###
CCCCCCCCCCCCC&CCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCâ–’
I2C:   ready
DRAM:  512 MiB
BeagleBone Black:
Net:   eth0: MII MODE
cpsw, usb_ether
starting USB...
@RobertCNelson,
Sorry just realized from my own post, that the SD card had the wrong files on it (thus the unrecognized file system). I’m re-imaging with the etcher software.
@RobertCNelson,
this is the result now…
CCCCCCCCCCCC
U-Boot SPL 2019.04-00002-g9ca2c5819f (May 20 2019 - 13:06:28 -0500)
U-Boot 2019.04-00002-g9ca2c5819f (May 20 2019 - 13:06:28 -0500), Build: jenkins-github_Bootloader-Builder-120
I2C:   ready
DRAM:  512 MiB
BeagleBone Black:
Net:   eth0: MII MODE
cpsw, usb_ether
starting USB...
@jeffdk
Looking at your boot log, this stands out:
Are their any pins bent on your microSD slot? The bootrom is able to pull the files off the microSD, but as soon as u-boot tries to access the device it fails. (the bootrom access the microSD in the most simple setup, where as u-boot is configured to fully take advantaged of the device.)
Regards,
@RobertCNelson,
Sure enough, one pin was bent up and not making contact with the SD card. I bent it down and now am able to boot from the SD card! Thank you so much! :joy:
Jeff
