I ran: [sudo ./bin/create-sdcard.sh]
This script will create a bootable SD card from custom or pre-built binaries.
The script must be run with root permissions and from the bin directory of
the SDK
Example:
$ sudo ./create-sdcard.sh
Formatting can be skipped if the SD card is already formatted and
partitioned properly.
Available Drives to write images to:
# major minor size name
1: 8 0 976762584 sda
2: 8 32 15558144 sdc
Enter Device Number or n to exit: 2
sdc was selected
/dev/sdc is an sdx device
Current size of sdc1 131072 bytes
Current size of sdc2 15426031 bytes
Detected device has 2 partitions already
Re-partitioning will allow the choice of 2 or 3 partitions
Would you like to re-partition the drive anyways [y/n] : y
Now partitioning sdc ...
Select 2 partitions if only need boot and rootfs (most users).
Select 3 partitions if need SDK & other content on SD card. This is
usually used by device manufacturers with access to partition tarballs.
****WARNING**** continuing will erase all data on sdc
Number of partitions needed [2/3] : 2
Now partitioning sdc with 2 partitions...
Now making 2 partitions
1024+0 records in
1024+0 records out
1048576 bytes (1.0 MB, 1.0 MiB) copied, 0.153431 s, 6.8 MB/s
DISK SIZE - 15931539456 bytes
Welcome to fdisk (util-linux 2.36.1).
Changes will remain in memory only, until you decide to write them.
Be careful before using the write command.
Device does not contain a recognized partition table.
Created a new DOS disklabel with disk identifier 0x72d4505e.
Command (m for help): Partition type
p primary (0 primary, 0 extended, 4 free)
e extended (container for logical partitions)
Select (default p): Partition number (1-4, default 1): First sector (2048-31116287, default 2048): Last sector, +/-sectors or +/-size{K,M,G,T,P} (2048-31116287, default 31116287):
Created a new partition 1 of type 'Linux' and of size 75 MiB.
Partition #1 contains a vfat signature.
p primary (1 primary, 0 extended, 3 free)
Select (default p): Partition number (2-4, default 2): First sector (155648-31116287, default 155648): Last sector, +/-sectors or +/-size{K,M,G,T,P} (155648-31116287, default 31116287):
Created a new partition 2 of type 'Linux' and of size 14.8 GiB.
Command (m for help): Partition number (1,2, default 2): Hex code or alias (type L to list all):
Changed type of partition 'Linux' to 'W95 FAT32 (LBA)'.
The bootable flag on partition 1 is enabled now.
Command (m for help): The partition table has been altered.
Calling ioctl() to re-read partition table.
Syncing disks.
Partitioning Boot
mkfs.fat 4.2 (2021-01-31)
mkfs.fat: Warning: lowercase labels might not work properly on some systems
Partitioning rootfs
mke2fs 1.46.2 (28-Feb-2021)
Creating filesystem with 3870080 4k blocks and 969136 inodes
Filesystem UUID: 12962e65-3c68-4f33-9278-55c7cb8474b1
Superblock backups stored on blocks:
32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208
Allocating group tables: done
Writing inode tables: done
Creating journal (16384 blocks): done
Writing superblocks and filesystem accounting information: done
Partitioning is now done
Continue to install filesystem or select 'n' to safe exit
**Warning** Continuing will erase files any files in the partitions
Would you like to continue? [y/n] : y
Mount the partitions
Emptying partitions
Syncing....
Choose file path to install from
1 ) Install pre-built images from SDK
2 ) Enter in custom boot and rootfs file paths
Choose now [1/2] : 1
Will now install from SDK pre-built images
now installing: ti-processor-sdk-linux-am335x-evm-07.03.00.005
Multiple rootfs Tarballs found
1:tisdk-default-image-am335x-evm.tar.xz
2:tisdk-docker-rootfs-image-am335x-evm.tar.xz
3:tisdk-base-image-am335x-evm.tar.xz
4:tisdk-tiny-image-am335x-evm.tar.xz
Enter Number of rootfs Tarball: 3
Copying files now... will take minutes
Copying boot partition
MLO copied
u-boot.img copied
Copying rootfs System partition
Syncing...
Un-mount the partitions
Remove created temp directories
Operation Finished
Looking at the drive with: [sudo fdisk -l /dev/sdc]
voodoo@hestia:~/ti-processor-sdk-linux-am335x-evm-07.03.00.005$ sudo fdisk -l /dev/sdc
Disk /dev/sdc: 14.84 GiB, 15931539456 bytes, 31116288 sectors
Disk model: USB3.0 CRW-SM/xD
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x72d4505e
Device Boot Start End Sectors Size Id Type
/dev/sdc1 * 2048 155647 153600 75M c W95 FAT32 (LBA)
/dev/sdc2 155648 31116287 30960640 14.8G 83 Linux
voodoo@hestia:~/ti-processor-sdk-linux-am335x-evm-07.03.00.005$ lsblk | grep sdc
sdc 8:32 1 14.8G 0 disk
├─sdc1 8:33 1 75M 0 part /media/voodoo/boot
└─sdc2 8:34 1 14.8G 0 part /media/voodoo/rootfs
Boot Partition:
voodoo@hestia:~/ti-processor-sdk-linux-am335x-evm-07.03.00.005$ tree /media/voodoo/boot/
/media/voodoo/boot/
├── MLO
└── u-boot.img
0 directories, 2 files
Rootfs Partition:
voodoo@hestia:~/ti-processor-sdk-linux-am335x-evm-07.03.00.005$ ls -lha /media/voodoo/rootfs/
total 68K
drwxr-xr-x 17 root root 4.0K May 24 2021 .
drwxr-x---+ 4 root root 4.0K Jan 19 17:22 ..
drwxr-xr-x 2 root root 4.0K May 24 2021 bin
drwxr-xr-x 2 root root 4.0K May 24 2021 boot
drwxr-xr-x 2 root root 4.0K May 24 2021 dev
drwxr-xr-x 34 root root 4.0K May 24 2021 etc
drwxr-xr-x 3 root root 4.0K May 24 2021 home
lrwxrwxrwx 1 root root 20 May 24 2021 init -> /lib/systemd/systemd
drwxr-xr-x 9 root root 4.0K May 24 2021 lib
lrwxrwxrwx 1 root root 19 May 24 2021 linuxrc -> /bin/busybox.nosuid
drwxr-xr-x 2 root root 4.0K May 24 2021 media
drwxr-xr-x 2 root root 4.0K May 24 2021 mnt
dr-xr-xr-x 2 root root 4.0K May 24 2021 proc
drwxr-xr-x 2 root root 4.0K May 24 2021 run
drwxr-xr-x 2 root root 4.0K May 24 2021 sbin
dr-xr-xr-x 2 root root 4.0K May 24 2021 sys
drwxrwxrwt 2 root root 4.0K May 24 2021 tmp
drwxr-xr-x 10 root root 4.0K May 24 2021 usr
drwxr-xr-x 8 root root 4.0K May 24 2021 var
Bootup:
U-Boot SPL 2020.01-g2781231a33 (May 24 2021 - 11:08:13 +0000)
Trying to boot from MMC1
U-Boot 2020.01-g2781231a33 (May 24 2021 - 11:08:13 +0000)
CPU : AM335X-GP rev 2.1
Model: TI AM335x BeagleBone Black
DRAM: 512 MiB
WDT: Started with servicing (60s timeout)
NAND: 0 MiB
MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1
Loading Environment from FAT... *** Warning - bad CRC, using default environment
<ethaddr> not set. Validating first E-fuse MAC
Net: eth0: ethernet@4a100000
Warning: usb_ether MAC addresses don't match:
Address in ROM is de:ad:be:ef:00:01
Address in environment is 80:f5:b5:aa:4f:ba
, eth1: usb_ether
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
Scanning mmc 0:1...
4653568 bytes read in 310 ms (14.3 MiB/s)
61337 bytes read in 8 ms (7.3 MiB/s)
## Flattened Device Tree blob at 88000000
Booting using the fdt blob at 0x88000000
Loading Device Tree to 8ffee000, end 8fffff98 ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 5.4.106-g023faefa70 (oe-user@oe-host) (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #1 PREEMPT Mon May 24 09:04:10 UTC 2021
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: TI AM335x BeagleBone Black
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] cma: Reserved 48 MiB at 0x9c800000
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] AM335X ES2.1 (sgx neon)
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 129666
[ 0.000000] Kernel command line: console=ttyO0,115200n8 root=PARTUUID=72d4505e-02 rw rootfstype=ext4 rootwait
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 453832K/523264K available (9216K kernel code, 295K rwdata, 3092K rodata, 1024K init, 254K bss, 20280K reserved, 49152K cma-reserved, 0K highmem)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] IRQ: Found an INTC at 0x(ptrval) (revision 5.0) with 128 interrupts
[ 0.000000] random: get_random_bytes called from start_kernel+0x2b4/0x470 with crng_init=0
[ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz
[ 0.000017] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000037] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000047] OMAP clocksource: timer1 at 24000000 Hz
[ 0.000291] timer_probe: no matching timers found
[ 0.000462] Console: colour dummy device 80x30
[ 0.000494] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[ 0.000499] This ensures that you still see kernel messages. Please
[ 0.000504] update your kernel commandline.
[ 0.000552] Calibrating delay loop... 996.14 BogoMIPS (lpj=4980736)
[ 0.089151] pid_max: default: 32768 minimum: 301
[ 0.089354] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.089367] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.090209] CPU: Testing write buffer coherency: ok
[ 0.090275] CPU0: Spectre v2: using BPIALL workaround
[ 0.091057] Setting up static identity map for 0x80100000 - 0x80100060
[ 0.091195] rcu: Hierarchical SRCU implementation.
[ 0.091271] EFI services will not be available.
[ 0.091646] devtmpfs: initialized
[ 0.101403] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.101779] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.101800] futex hash table entries: 256 (order: -1, 3072 bytes, linear)
[ 0.105385] pinctrl core: initialized pinctrl subsystem
[ 0.106135] DMI not present or invalid.
[ 0.106594] NET: Registered protocol family 16
[ 0.108736] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.132162] l3-aon-clkctrl:0000:0: failed to disable
[ 0.134217] cpuidle: using governor ladder
[ 0.134250] cpuidle: using governor menu
[ 0.149219] No ATAGs?
[ 0.149231] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.163929] debugfs: Directory '49000000.edma' with parent 'dmaengine' already present!
[ 0.163964] edma 49000000.edma: TI EDMA DMA engine driver
[ 0.165614] iommu: Default domain type: Translated
[ 0.167616] SCSI subsystem initialized
[ 0.168051] mc: Linux media interface: v0.10
[ 0.168095] videodev: Linux video capture interface: v2.00
[ 0.168189] pps_core: LinuxPPS API ver. 1 registered
[ 0.168197] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.168215] PTP clock support registered
[ 0.168245] EDAC MC: Ver: 3.0.0
[ 0.169544] Advanced Linux Sound Architecture Driver Initialized.
[ 0.170715] clocksource: Switched to clocksource timer1
[ 0.177682] thermal_sys: Registered thermal governor 'fair_share'
[ 0.177691] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.177707] thermal_sys: Registered thermal governor 'step_wise'
[ 0.177712] thermal_sys: Registered thermal governor 'user_space'
[ 0.177718] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.178270] NET: Registered protocol family 2
[ 0.179007] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[ 0.179035] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[ 0.179074] TCP bind hash table entries: 4096 (order: 2, 16384 bytes, linear)
[ 0.179111] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.179558] UDP hash table entries: 256 (order: 0, 4096 bytes, linear)
[ 0.179576] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes, linear)
[ 0.179750] NET: Registered protocol family 1
[ 0.180302] RPC: Registered named UNIX socket transport module.
[ 0.180314] RPC: Registered udp transport module.
[ 0.180320] RPC: Registered tcp transport module.
[ 0.180324] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.180340] PCI: CLS 0 bytes, default 64
[ 0.181346] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[ 0.182511] Initialise system trusted keyrings
[ 0.182867] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[ 0.187334] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.188130] NFS: Registering the id_resolver key type
[ 0.188173] Key type id_resolver registered
[ 0.188180] Key type id_legacy registered
[ 0.188221] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.188889] Key type asymmetric registered
[ 0.188902] Asymmetric key parser 'x509' registered
[ 0.188951] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 0.188961] io scheduler mq-deadline registered
[ 0.188967] io scheduler kyber registered
[ 0.193971] OMAP GPIO hardware version 0.1
[ 0.218866] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[ 0.243862] pinctrl-single 44e10800.pinmux: 142 pins, size 568
[ 0.290501] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[ 0.294785] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 29, base_baud = 3000000) is a 8250
[ 0.907313] printk: console [ttyS0] enabled
[ 0.914101] omap_rng 48310000.rng: Random Number Generator ver. 20
[ 0.920887] random: fast init done
[ 0.924548] random: crng init done
[ 0.943891] brd: module loaded
[ 0.953641] loop: module loaded
[ 0.961631] libphy: Fixed MDIO Bus: probed
[ 1.020744] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000
[ 1.028448] libphy: 4a101000.mdio: probed
[ 1.033962] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8710/LAN8720
[ 1.043376] cpsw 4a100000.ethernet: initialized cpsw ale version 1.4
[ 1.049758] cpsw 4a100000.ethernet: ALE Table size 1024
[ 1.055158] cpsw 4a100000.ethernet: cpts: overflow check period 500 (jiffies)
[ 1.062449] cpsw 4a100000.ethernet: Detected MACID = 80:f5:b5:aa:4f:b8
[ 1.070883] i2c /dev entries driver
[ 1.076824] cpuidle: enable-method property 'ti,am3352' found operations
[ 1.084312] sdhci: Secure Digital Host Controller Interface driver
[ 1.090525] sdhci: Copyright(c) Pierre Ossman
[ 1.096242] omap_gpio 44e07000.gpio: Could not set line 6 debounce to 200000 microseconds (-22)
[ 1.105041] omap_hsmmc 48060000.mmc: Got CD GPIO
[ 1.159026] omap_hsmmc 47810000.mmc: RX DMA channel request failed
[ 1.167897] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.176408] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.182646] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.194858] davinci-mcasp 48038000.mcasp: IRQ common not found
[ 1.202552] NET: Registered protocol family 10
[ 1.207289] mmc0: new high speed SDHC card at address e624
[ 1.213963] Segment Routing with IPv6
[ 1.217720] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 1.224581] mmcblk0: mmc0:e624 SE16G 14.8 GiB
[ 1.230993] mmcblk0: p1 p2
[ 1.234414] NET: Registered protocol family 17
[ 1.240258] Key type dns_resolver registered
[ 1.244820] omap_voltage_late_init: Voltage driver support not added
[ 1.251936] Loading compiled-in X.509 certificates
[ 1.298910] mmc1: new high speed MMC card at address 0001
[ 1.306771] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[ 1.312291] mmcblk1: mmc1:0001 M62704 3.56 GiB
[ 1.317061] mmcblk1boot0: mmc1:0001 M62704 partition 1 2.00 MiB
[ 1.324316] mmcblk1boot1: mmc1:0001 M62704 partition 2 2.00 MiB
[ 1.330501] mmcblk1rpmb: mmc1:0001 M62704 partition 3 512 KiB, chardev (243:0)
[ 1.339475] mmcblk1: p1
[ 1.463000] tda998x 0-0070: found TDA19988
[ 1.470305] tilcdc 4830e000.lcdc: bound 0-0070 (ops tda998x_ops)
[ 1.476436] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.483090] [drm] No driver support for vblank timestamp query.
[ 1.489673] [drm] Initialized tilcdc 1.0.0 20121205 for 4830e000.lcdc on minor 0
[ 1.497451] [drm] Cannot find any crtc or sizes
[ 1.502278] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 1.508780] [drm] Cannot find any crtc or sizes
[ 1.514577] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 100 kHz
[ 1.525007] hctosys: unable to open rtc device (rtc0)
[ 1.530973] ALSA device list:
[ 1.533967] No soundcards found.
[ 1.567378] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.575744] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 1.589750] devtmpfs: mounted
[ 1.594835] Freeing unused kernel memory: 1024K
[ 1.600027] Run /sbin/init as init process
[ 1.924391] systemd[1]: System time before build time, advancing clock.
[ 1.986524] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[ 2.009087] systemd[1]: Detected architecture arm.
Welcome to Arago 2020.09!
[ 2.052186] systemd[1]: Set hostname to <am335x-evm>.
[ 2.073501] systemd[1]: Initializing machine ID from random generator.
[ 2.808086] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[ 2.820859] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[ 2.833948] systemd[1]: Created slice system-getty.slice.
[ OK ] Created slice system-getty.slice.
[ 2.877540] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 2.923058] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 2.962451] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password …ts to Console Directory Watch.
[ 3.002197] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password R…uests to Wall Directory Watch.
[ 3.044008] systemd[1]: Reached target Paths.
[ OK ] Reached target Paths.
[ 3.071238] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 3.113253] systemd[1]: Reached target Slices.
[ OK ] Reached target Slices.
[ 3.141315] systemd[1]: Reached target Swap.
[ OK ] Reached target Swap.
[ 3.174069] systemd[1]: Listening on RPCbind Server Activation Socket.
[ OK ] Listening on RPCbind Server Activation Socket.
[ 3.211565] systemd[1]: Reached target RPC Port Mapper.
[ OK ] Reached target RPC Port Mapper.
[ 3.271166] systemd[1]: Listening on Process Core Dump Socket.
[ OK ] Listening on Process Core Dump Socket.
[ 3.314127] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ OK ] Listening on initctl Compatibility Named Pipe.
[ 3.407569] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[ 3.417353] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 3.455253] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 3.495755] systemd[1]: Listening on Network Service Netlink Socket.
[ OK ] Listening on Network Service Netlink Socket.
[ 3.532366] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 3.572765] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 3.613157] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[ 3.631828] systemd[1]: Mounting POSIX Message Queue File System...
[ 3.660397] systemd[1]: Mounting Kernel Debug File System...
[ 3.721586] systemd[1]: Mounting Temporary Directory (/tmp)...
[ 3.753199] systemd[1]: Starting Create list of static device nodes for the current kernel...
Starting Create list of st…odes for the current kernel...
[ 3.817125] systemd[1]: Starting Start psplash boot splash screen...
[ 3.869586] systemd[1]: Starting RPC Bind...
[ 3.911711] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 3.947376] systemd[1]: Starting Journal Service...
[ 3.995064] systemd[1]: Condition check resulted in Load Kernel Modules being skipped.
[ 4.011818] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[ 4.044422] systemd[1]: Mounting Kernel Configuration File System...
[ 4.106844] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 4.176959] systemd[1]: Starting Apply Kernel Variables...
[ 4.206299] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 4.244120] systemd[1]: Starting udev Coldplug all Devices...
[ 4.290343] systemd[1]: Started RPC Bind.
[ OK ] Started RPC Bind.
[ 4.326855] systemd[1]: Started Journal Service.
[ OK ] Started Journal Service.
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Mounted Kernel Debug File System.
[ OK ] Mounted Temporary Directory (/tmp).
[ OK ] Started Create list of sta… nodes for the current kernel.
[FAILED] Failed to start Start psplash boot splash screen.
See 'systemctl status psplash-start.service' for details.
[DEPEND] Dependency failed for Star…progress communication helper.
[ OK ] Mounted Kernel Configuration File System.
[ OK ] Started Remount Root and Kernel File Systems.
[ OK ] Started Apply Kernel Variables.
Starting Flush Journal to Persistent Storage...
[ 4.783566] systemd-journald[82]: Received client request to flush runtime journal.
Starting Create System Users...
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Started Create System Users.
Starting Create Static Device Nodes in /dev...
[ OK ] Started Create Static Device Nodes in /dev.
[ OK ] Reached target Local File Systems (Pre).
Mounting /media/ram...
Mounting /var/volatile...
Starting udev Kernel Device Manager...
[ OK ] Mounted /media/ram.
[ OK ] Mounted /var/volatile.
Starting Load/Save Random Seed...
[ OK ] Reached target Local File Systems.
Starting Rebuild Dynamic Linker Cache...
Starting Create Volatile Files and Directories...
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started Load/Save Random Seed.
[ OK ] Started Create Volatile Files and Directories.
Starting Run pending postinsts...
Starting Rebuild Journal Catalog...
Starting Network Time Synchronization...
Starting Update UTMP about System Boot/Shutdown...
[ OK ] Started Rebuild Dynamic Linker Cache.
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Started Rebuild Journal Catalog.
Starting Update is Completed...
[ OK ] Started Update is Completed.
[ 7.792091] remoteproc remoteproc0: wkup_m3 is available
[ OK ] Started udev Coldplug all Devices.
[ OK ] Started Network Time Synchronization.
[ 8.491293] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ OK ] Reached target System Time Set.
[ 8.510610] omap_rtc 44e3e000.rtc: registered as rtc0
[ OK ] Reached target System Time Synchronized.
[ 9.181117] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 9.254427] remoteproc remoteproc0: powering up wkup_m3
[ 9.355376] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 243196
[ 9.511217] remoteproc remoteproc0: remote processor wkup_m3 is now up
[ 9.511238] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x192
[ OK ] Started Run pending postinsts.
[ OK ] Reached target System Initialization.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target Timers.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
[ OK ] Started D-Bus System Message Bus.
Starting Print notice about GPLv3 packages...
Starting IPv6 Packet Filtering Framework...
Starting IPv4 Packet Filtering Framework...
[ 11.799758] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
Starting Login Service...
Starting telnetd.service...
[ 12.095805] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[ OK ] Started IPv6 Packet Filtering Framework.
[ 12.210679] PM: bootloader does not support rtc-only!
[ OK ] Started IPv4 Packet Filtering Framework.
[ 12.257665] omap-aes 53500000.aes: will run requests pump with realtime priority
[ 12.827646] asoc-simple-card sound: i2s-hifi <-> 48038000.mcasp mapping ok
[ OK ] Started telnetd.service.
[ 12.909898] asoc-simple-card sound: ASoC: no DMI vendor name!
NOTICE: This file system contains the following GPLv3 package[ 18.955689] am335x-phy-driver 47401300.usb-phy: 47401300.usb-phy supply vcc not found, using dummy regulator
s:
bash
cifs-utils
dosfstools
less
libdw1
libelf1
If you do not wish to distribute GPLv3 components please remove
the above packages prior to distribution. This can be done us[ 18.980545] usbcore: registered new interface driver usbfs
ing
the opkg remove command. i.e.:
opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
will be notified of the dependent packages. You should
use the --force-removal-of-dependent-packages option to
also remove the dependent packages as well
[ 19.051150] usbcore: registered new interface driver hub
[ 19.056594] usbcore: registered new device driver usb
[ OK ] Started Print notice about GPLv3 packages.
[ 19.115024] am335x-phy-driver 47401b00.usb-phy: 47401b00.usb-phy supply vcc not found, using dummy regulator
[ 19.305165] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[ 19.310547] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[ 19.482537] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[ 19.546747] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 19.610388] usb usb1: Product: MUSB HDRC host driver
[ 19.660958] usb usb1: Manufacturer: Linux 5.4.106-g023faefa70 musb-hcd
[ 19.667535] usb usb1: SerialNumber: musb-hdrc.1
[ 19.750057] hub 1-0:1.0: USB hub found
[ 19.781226] hub 1-0:1.0: 1 port detected
[ 20.563698] remoteproc remoteproc1: 4a334000.pru is available
[ 20.569611] pru-rproc 4a334000.pru: PRU rproc node /ocp/interconnect@4a000000/segment@0/target-module@300000/pruss@0/pru@34000 probed successfully
[ 20.789775] remoteproc remoteproc2: 4a338000.pru is available
[ 20.835435] pru-rproc 4a338000.pru: PRU rproc node /ocp/interconnect@4a000000/segment@0/target-module@300000/pruss@0/pru@38000 probed successfully
[ OK ] Started Login Service.
[ OK ] Created slice system-systemd\x2dfsck.slice.
[ OK ] Reached target Network (Pre).
[ OK ] Reached target Hardware activated USB gadget.
[ OK ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
Starting Save/Restore Sound Card State...
Starting File System Check on /dev/mmcblk0p1...
Starting File System Check on /dev/mmcblk1p1...
Starting Network Service...
[ OK ] Started Save/Restore Sound Card State.
[ OK ] Reached target Sound Card.
[ OK ] Started File System Check on /dev/mmcblk0p1.
Mounting /run/media/mmcblk0p1...
[ OK ] Started Network Service.
[ 23.660464] cpsw 4a100000.ethernet: initializing cpsw version 1.12 (0)
[ OK ] Started File System Check on /dev/mmcblk1p1.
[ 23.781896] SMSC LAN8710/LAN8720 4a101000.mdio:00: attached PHY driver [SMSC LAN8710/LAN8720] (mii_bus:phy_addr=4a101000.mdio:00, irq=POLL)
[ OK ] Mounted /run/media/mmcblk0p1.
Mounting /run/media/mmcblk1p1...
Starting Wait for Network to be Configured...
[ 23.932883] EXT4-fs (mmcblk1p1): mounted filesystem with ordered data mode. Opts: (null)
Starting Network Name Resolution...
[ OK ] Mounted /run/media/mmcblk1p1.
[ OK ] Started Network Name Resolution.
[ OK ] Reached target Network.
[ OK ] Reached target Host and Network Name Lookups.
Starting Avahi mDNS/DNS-SD Stack...
[ OK ] Started NFS status monitor for NFSv2/3 locking..
Starting Permit User Sessions...
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ OK ] Started Permit User Sessions.
[ OK ] Started Getty on tty1.
[ OK ] Started Serial Getty on ttyS0.
[ OK ] Started Serial Getty on ttyS3.
[ OK ] Reached target Login Prompts.
Starting Synchronize System and HW clocks...
[ OK ] Started Synchronize System and HW clocks.
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org am335x-evm ttyS0
Arago 2020.09 am335x-evm ttyS0
am335x-evm login:
If you still can’t get, just take out the microSD and let it boot the the default eMMC image…
Login as root (password: root)…
run:
dd if=/dev/zero of=/dev/mmcblk1
Give 5-10 seconds, then kill it with “crl-c”…
Now power off and plug in microSD… Should always boot…
Regards
