I am converting a design with 150+ parts to work at low temperatures ( -30C) and I wanted to know if there was a way to check the BOM for parts that do not fall in this range. Is it possible for the export BOM feature in digikey to export with an operating temp column?
Obviously I could do this manually but I wanted to know if there was a way to speed up the process
There’s not a brain dead easy way to do this today using only features on the website. The easiest way would be to upload the list of parts to our BOM manager and use that to click each link to gather the info you need.
If you have a programming background, conceptually this would be fairly straightforward to do with the Digi-Key API found at https://developer.digikey.com/ .
