CHP2512K10R0FBT from Vishay Sfernice (Digi-Key Number 716-CHP2512K10R0FBTTR-ND) is a non-stock item in our catalog, if you need an alternative we have the following linked options available: Chip Resistor - Surface Mount | Resistors | DigiKey
Please note that the original part number is described as a ‘High Stability’ resistor, and while the basic specifications match on these alternatives, you should still review them to verify that they will work in your application.
