Customer called looking for the RCA040275K0FKED 0402 SMD Resistor from Vishay/Draloric, which DigiKey does not carry.
Looking at the Vishay Datasheet for this Resistor, we can offer a very close substitute that is carried by DigiKey.
2019-RK73H1ERTTP7502FCT-ND, which has a Manufacturer’s part number RK73H1ERTTP7502F, and is Manufactured by KOA Speer.
This is a 75K ohm Resistor, 0402 size, 1% tolerance, Anti-Sulfer and Automotive Grade.
It also has better ratings for the Wattage and Voltage.
Here is the KOA Datasheet so you can compare the two,and verify compatibility to your application.
