Clarification on Bulging Observed in EPCOS-TDK Capacitor B43541A9687M000
If you have observed bulging in the EPCOS - TDK B43541A9687M000 capacitor, as shown in the image below, and are wondering:
“What is the cause of this bulging phenomenon, and does it impact the product?”
Please refer to the clarification provided by the manufacturer below.
“The air bubble under the bottom foil is part of our technology. On the Multi Pin assembly line the bottom foils are placed by automatic vacuum pipettes, which pulls (sucks) the foil in the middle before it is placed on the can. Due to this, there is almost always some remaining air under the bottom disc.
It will not influence the insulation resistance of the capacitor and will not cause any other problem. The bottom foil is attached with enough strong force, so it will not peel off.
This is not considered as failure - the air bubble should not cover the whole bottom surface."
Applicable Part Numbers
DigiKey Part Number Manufacturer Part Number
495-77464-ND B43541B8476M000
495-B43541B8476M080-ND B43541B8476M080
495-77465-ND B43541B9157M000
495-B43541A7107M000-ND B43541A7107M000
495-77460-ND B43541B2108M000
495-77461-ND B43541B7107M000
495-77462-ND B43541B8157M000
495-B43541A9227M000-ND B43541A9227M000
495-77452-ND B43541A5567M000
495-77458-ND B43541A9397M000
495-B43541A9477M000-ND B43541A9477M000
495-77463-ND B43541B8187M000
495-B43541A7337M000-ND B43541A7337M000
495-B43541F2827M000-ND B43541F2827M000
495-B43541B2108M080-ND B43541B2108M080
495-B43541B6227M000-ND B43541B6227M000
495-B43541A9687M000-ND B43541A9687M000
495-77456-ND B43541A8227M000
495-77455-ND B43541A7227M000
495-B43541A7397M000-ND B43541A7397M000
B43541A8277M000-ND B43541A8277M000
495-B43541A6477M000-ND B43541A6477M000
495-77451-ND B43541A5337M000
B43541B8227M007-ND B43541B8227M007
B43541E2277M000-ND B43541E2277M000
495-B43541B9157M060-ND B43541B9157M060
495-B43541B8476M060-ND B43541B8476M060
495-77454-ND B43541A6686M000
495-B43541F2477M060-ND B43541F2477M060
B43541B7826M062-ND B43541B7826M062
B43541B9227M087-ND B43541B9227M087
B43541A9127M000-ND B43541A9127M000
B43541A9157M000-ND B43541A9157M000
B43541A9337M002-ND B43541A9337M002
B43541A9277M002-ND B43541A9277M002
495-B43541B5277M060-ND B43541B5277M060
495-B43541A9477M060-ND B43541A9477M060
B43541C8127M080-ND B43541C8127M080
495-B43541B9477M000-ND B43541B9477M000
B43541B7127M000-ND B43541B7127M000
B43541A8157M000-ND B43541A8157M000
B43541A9397M002-ND B43541A9397M002
B43541B7157M000-ND B43541B7157M000
B43541A9687M060-ND B43541A9687M060
B43541A9477M002-ND B43541A9477M002
B43541A9477M007-ND B43541A9477M007
B43541B8187M080-ND B43541B8187M080
B43541A5477M082-ND B43541A5477M082
495-B43541A6277M000-ND B43541A6277M000
B43541A7277M000-ND B43541A7277M000
495-B43541A6477M060-ND B43541A6477M060
B43541B7277M007-ND B43541B7277M007
495-B43541A6397M060-ND B43541A6397M060
495-B43541A9687M062-ND B43541A9687M062
B43541A8277M067-ND B43541A8277M067
B43541A6397M000-ND B43541A6397M000
B43541A7397M002-ND B43541A7397M002
B43541A8476M000-ND B43541A8476M000
B43541B8686M062-ND B43541B8686M062
