CM_USB2_25 Detailed Product Dimensions
------Question for CM_USB2_25 Please Put your question below------
Hello. A 3D model or drawing with hole locations and other major dimensions would be useful.
Hello jacob.laube,
I have reached out to the manufacturer to see if this is something they can provide, as soon as I get a response I will follow up with you.
“Hello,
Here is what the manufacturer responded with on this:
It is possible to provide after order, before ordering we don’t provide any drawings.
The pcb has a 38 x 38 size but it can also break away in a 32x32 size.
It is a simple square.”
If you have a DigiKey SO# or INV#, this can be sent to Techs@digikey.com and we can request this for you.
Yeah, I had gathered that much. I was curious about the lens height and the surface mounted components. I am trying to design a mount for it
