你好,CO2520-25.000-1.8-50-EXT-T-TR 能替代型号CO2520-25.000-1.8-15-TR-NS1吗,有没有这方面的文件可提供,两者之间是通用型号吗
------Question for CO2520-25.000-1.8-50-EXT-T-TR Please Put your question below------
Hello Zhangwei and welcome to the DigiKey TechForum.
From what I can find, it appears that the NS1 may be a call out to revision. Based on the rest of the part number, it would appear that the only other difference would be Frequency Stability. CO2520-25.000-1.8-50 would have +/-50PPM and the other would have +/-15PPM. It may work as an alternative, but would depend on your application.
Translated with Google.
您好,张伟,欢迎来到 DigiKey 技术论坛。
据我所知,NS1 可能指的是版本号。根据零件号的其他部分,唯一的区别似乎是频率稳定性。CO2520-25.000-1.8-50 的频率稳定性为 +/-50 PPM,而另一个型号的频率稳定性为 +/-15 PPM。它或许可以作为替代品,但这取决于您的具体应用。
