------Question for CG-3510S4-BOARD Please Put your question below------
Can the different ports of this device all be used to communicate with each other? I am trying to create a enclosure that has multiple external USB connections, including the front end computer, but there is also a communicating USB device within the controller. I am wondering if I could use the 4 outward facing USB type B connectors to interface the external USB devices, including the PCB, and then use the inward facing USB type A connector to connect the internal USB device.
Thanks!
