Companies which upgrade commercial components to JANTX
Hello DigiKey, Greetings for the day! Is there any companies which will upgrade commercial components to JANTX screening level. Thanks & regards, BD
Hello @bharath.dhage,
Yes, DigiKey does sell JANTX components. Here is an example:
However, please see DigiKey’s terms and conditions. Specifically:
In addition, you acknowledge that DigiKey is not on the Qualified Manufacturers List (“QML”), and does not sell Qualified Product List (“QPL”) components for military applications.
Recommend:
  • Locate part in DigiKey using two keywords such as, “JANTX transistor” od “JANTX diode”.
  • Contact individual manufacturers to determine availability of screening levels.
Best wishes,
Thank you very much.
