------Question for NOZZLE-GREEN Please Put your question below------
Is this green nozzle tip (3M157629-ND) suitable for 3M Scotch Weld Epoxy Adhesive DP100 NS translucent?
@digitalvault Welcome to TechForum!
It depends on which container you use.
DP100NS has two different container types, 48.5 ml and 200 ml Duo-Pak.
If you use 48.5 ml duo pack, then the appropriate applicator would be 3M157692-ND, and you can use NOZZLE-GREEN, since the mix-ratio of DP100NS is 1:1.
You can find applicator and nozzles chart here:
3M Scotch-Weld - Applicators and Nozzles - Equipment, Tools & Supplies / Tapes, Adhesives and Materials - DigiKey TechForum - An Electronic Component and Engineering Solution Forum
