Hello, Trying to ID this connector. Its a 1.5mm pitch like the ZH connectors and the ZH housing mates to the PCB header and the locking tabs are in the same spots.
Very similar to JST ZH but unknown connector pin will not seat fully into a JST ZH due to this little ramp or tab at the front of the pin. The ZH pin will slide into the unknown connector housing but not very securely due to locking tangs being different heights.
Picture of crimps show unknown connector Blue wire and JST ZH black wire straight from digikey.
Connector housing of unknown connector has these little slots that the Pin tab slides into, never seen that before.
Locking tangs on the pins are a little taller on this unknown connector as well.
I looked at the usual suspects JST Adam Tech Molex but not much luck.
Closest thing I could find is this: DL15009(ZHF Series)
The product that this is inside came from Korea if thats any help.
Any help is greatly appreciated.
