they zip tied the wire too tight so these tiny wires got pinched, spliced out damaged wire but too close to connector so won’t lost need help finding replacement connector, or the pins and use same connector thnx, researched for a few hours some are close but not exact with latch, J1
Hello and welcome to the forum, @tkemp4! I did some searching and it looks like this could be part number 455-2152-ND, manufactured by JST.
I’d recommend double checking the dimensions to make sure it’s the right size though, to be sure. Are you able to get a measurement of the pitch, that is the distance between each pin? Measured from the center of one pin, to the center of the next pin on the connector.
thanks well I will buy it and see if it works, i have a lot of tools but not for these smaller precise fittings in small electronics so I bought a caliper to take these precise measurements. I remove one female pin from housing to see what it looks like and its rectangular, how do you measure that
