All,
Will you help ID this connector. Only the two outside pins are used. I can happily provide additional pictures and measurements as requested.
Thank you in advance.
Hello Adub99 and welcome to the DigiKey TechForum,
It appears that you may be looking for something like one of these connectors. I was uncertain of the pitch, but most of the other measurements appear to be fairly close.
You may want to check the pitch (distance from center pin to adjacent pin) to confirm if one of these may work for you.
Thank you Nick.
Those look like a good match Nick.
