I’m trying to identify the connector identified in the attached photos. Thanks in advance for your help and time.
Hello RJH and welcome to the DigiKey TechForum,
Unfortunately, I am not finding anything based on the images you provided below. We may have more luck if you were able to provide some dimensions, specifically the distance between the center of each contact?
Hello RJH,
Thank you for the measurements.
Unfortunately, we do not have a match to this connector.
I did not find anything that had a square housing, and a round housing, for the 2 contacts.
Hi Mark,
Thanks for investigating my inquiry and for the update. It must be a proprietary connector. I’ll continue to investigate options.
Regards,
RJ
