CONNECTORS
Hello Team,
could you please check and advise if P/N 739-105/100-000 can be used as an alternative to 739-105. and what is the difference between both?
Hello @malavb
the difference in the parts is;
part number 739-105/100-000 is a press in terminal block with a 300Volt 8Amp rating.
Whereas part number 739-105 is a solder terminal block with a 300Volt 10Amp rating.
