The MHDTZK9 series D-Sub connector from MH Connectors, for example, MHDTZK9-DM9P-K (DigiKey part# 4672-MHDTZK9-DM9P-K-ND) is not a shell only, rather it is a complete backshell kit (with a connector) individually wrapped by the manufacturer. This kit consists of MHDTZK9-RA-PC-K and MHDM9SP. For detailed information, please refer to the specification sheet.
MHDTZK9-DM9P-K backshell kit includes:
(2) backshell halves
(2) 4-40 thumbscrews
(2) housing screws
(1) set of compression inserts - various sizes for 9-37
Diameters 4mm (.157"), 5mm (.197"), 7mm (.276"), 9mm (.354")
(1) set of compression inserts - various sizes for 50
Diameters 11mm (.433"), 12.5mm (.492"), 14mm (.551"), 15mm (.591")
(1) MHDM9SP connector
Alternatively, if you’re just looking for the backshell (without the connectors), you can check out MHDTZK9-RA-PC-K.
Applicable Part Numbers
| DK Part # | Mfr Part # | |
| 4672-MHDTZK9-K-ND | MHDTZK9-K | |
| 4672-MHDTZK15-RA-K-ND | MHDTZK15-RA-K | |
| 4672-MHDTZK9-RA-PC-K-ND | MHDTZK9-RA-PC-K | |
| 4672-MHDTZK9-BK-RA-PC-BK-K-ND | MHDTZK9-BK-RA-PC-BK-K | |
| 4672-MHDTZK15-RA-HI-K-ND | MHDTZK15-RA-HI-K | |
| 4672-MHDTZK9-DB9S-K-ND | MHDTZK9-DB9S-K | |
| 4672-MHDTZK25-RA-K-ND | MHDTZK25-RA-K | |
| 4672-MHDTZK15-DB15S-K-ND | MHDTZK15-DB15S-K | |
| 4672-MHDTZK37-RA-PC-K-ND | MHDTZK37-RA-PC-K | |
| 4672-MHDTZK37-RA-K-ND | MHDTZK37-RA-K | |
| 4672-MHDTZK9-DM9S-K-ND | MHDTZK9-DM9S-K | |
| 4672-MHDTZK25-RA-PC-K-ND | MHDTZK25-RA-PC-K | |
| 4672-MHDTZK25-DB25P-K-ND | MHDTZK25-DB25P-K | |
| 4672-MHDTZK37-K-ND | MHDTZK37-K | |
| 4672-MHDTZK9-DM9P-K-ND | MHDTZK9-DM9P-K | |
| 4672-MHDTZK15-DM15P-K-ND | MHDTZK15-DM15P-K | |
| 4672-MHDTZK50-K-ND | MHDTZK50-K | |
| 4672-MHDTZK15-BK-RA-PC-BK-K-ND | MHDTZK15-BK-RA-PC-BK-K | |
| 4672-MHDTZK15-BK-K-ND | MHDTZK15-BK-K | |
| 4672-MHDTZK25-BK-K-ND | MHDTZK25-BK-K | |
| 4672-MHDTZK37-RA-HI-K-ND | MHDTZK37-RA-HI-K | |
| 4672-MHDTZI25-K-ND | MHDTZI25-K | |
| 4672-MHDTZK25-DM25P-K-ND | MHDTZK25-DM25P-K | |
| 4672-MHDTZK15-K-ND | MHDTZK15-K | |
| 4672-MHDTZK25-BK-RA-PC-BK-K-ND | MHDTZK25-BK-RA-PC-BK-K | |
| 4672-MHDTZK37-BK-K-ND | MHDTZK37-BK-K | |
| 4672-MHDTZK9-RA-K-ND | MHDTZK9-RA-K | |
| 4672-MHDTZK15-RA-PC-K-ND | MHDTZK15-RA-PC-K | |
| 4672-MHDTZK9-DB9P-K-ND | MHDTZK9-DB9P-K | |
| 4672-MHDTZK15-DB15P-K-ND | MHDTZK15-DB15P-K | |
| 4672-MHDTZK25-DB25S-K-ND | MHDTZK25-DB25S-K | |
| 4672-MHDTZK25-K-ND | MHDTZK25-K | |
| 4672-MHDTZI50-K-ND | MHDTZK50-K | |
| 4672-MHDTZK9-RA-HI-K-ND | MHDTZK9-RA-HI-K | |
| 4672-MHDTZK9-BK-K-ND | MHDTZK9-BK-K | |
| 4672-MHDTZI09-K-ND | MHDTZI09-K | |
| 4672-MHDTZK37-BK-RA-PC-BK-K-ND | MHDTZK37-BK-RA-PC-BK-K | |
| 4672-MHDTZK25-RA-HI-K-ND | MHDTZK25-RA-HI-K | |
| 4672-MHDTZI15-K-ND | MHDTZI15-K | |
| 4672-MHDTZK15-DM15S-K-ND | MHDTZK15-DM15S-K | |
| 4672-MHDTZI37-K-ND | MHDTZI37-K | |
| 4672-MHDTZK25-DM25S-K-ND | MHDTZK25-DM25S-K |
