High density D-sub backshells or hoods
What size of backshell or hood can be used with high density D-sub connectors?
HD-15 position D-sub connectors use a DB-9 backshell
HD-26 position D-sub connectors use a DB15 back-shell
HD-44 position D-sub connectors use a DB25 back-shell
HD-62 position D-sub connectors use a DB37 back-shell
HD-78 position D-sub connectors use a DB50 back-shell
When looking at the High density d-sub connectors many of the options from the lists if you were to click into a part and scroll down should list the associated products. If there are options in the associated product box the correct size backshell/ hood should be listed.
Hi Michael,
Would you please freshen up the links to this FAQ? It’s exactly what I need. Thank you for preparing it. It almost avoided a new question to the forum.
Best Regards,
Chris
