I’m looking for a suggested product for controlling a 2 wire latching solenoid (datasheet is attached). I’ve been looking at using an H-Bridge however I am sure there must be a product available that will do this more elegantly. Any suggestions would be appreciated
The background of this request is trying to activate this solenoid using a Lorawan end node. This end node has 4 digital outputs. I would like to use 2 outputs per valve. Ideally I would prefer to connect these 4 outputs to a preassembled board which would do the voltage switching for me.
Based on the schematics below would it be possible to pulse the solenoid for 50ms? Would I need to have a 4700uF capacitor in the circuit?
Thanks,
Jonathan
