The HFKM/024-1ZST is a SPDT Automotive relay from Hongfa, which we do not carry, but we do have an alternative item in stock: 2449-A41CS24VDC-ND From CIT Relay and Switch.
This relay meets or exceeds the relevant electrical ratings and the footprint is largely the same, however, the pins are measured for a slightly smaller recommended hole diameter. Please review the datasheet for this item before using it in your application, especially to ensure it will fit in your PCB if being used as a replacement.
