Cross reference HF115F
Looking for cross reference relay
HF115F 012-1ZS3B(610)
Hello sbaraschuk,
From the datasheet I found on line, TE Connectivity Potter & Brumfield has some that should work for you. Click here for those options.
With the tolerance on the pin spacing, it should mount the same as your current relays.
Please check the datasheets to verify compatibility to your application.
