Custom FFC Cable Assemblies
DigiKey will make ribbon cable assemblies from the FFC connectors that we stock from TE Connectivity. They are listed as a Value-Add item on our web site. Cable assemblies can be made as Solder Tab to Solder Tab, Receptacle Housing to Solder Tab, or Receptacle Housing to Receptacle Housing.
These will be available in .050" (1.27mm) or .100" (2.54mm) pitch.
There will be a setup fee involved for all new custom cables.
Please Contact custom.orders@digikey.com with any questions on the assemblies.
For Example we will use the DigiKey part number A9BAG-0404F-ND
The Description will show it as FLEX CABLE - AFF04G/AF04/AFE04T
The AFF04G is the connector housing part number.
The socket contact for that is used in the housing is A124954TR-ND
The AFE04T is for the Solder Pin Tab that is used.
The AF04 will be the part number for the cable that is used.
“Parlex .050” (1.27mm) Flex Cable"
“Parlex .100” (2.54mm) Flex Cable"
The Cable Assembly part number breakdown will be:
The DigiKey Part number used for the TE Connectivity Housings and contacts are listed here:
.050" (1.27mm)
Male Solder Tab Pins
Plain Connector
Connector with Latch
.100" (2.54mm)
Plain Connector
The mating connectors for the cable assemblies will be the TE Connectivity AMPMODU MTE series shrouded headers.
Options for .050" (1.27mm)
Options for .100" (2.54mm)
