Davies Molding Part Availability Question
Hi I’m looking to replace a part I’m needing for rotary encoder, and was able to find the Davies Molding part number, 1475AY. Which is the 1475 knob in White, with a Knurl Molded Hole for mounting.
I was wondering if this would be a part Digikey could/would potentially carry at some point, or even the variant 1475-B, which is the same part but in black. Digikey does carry some of the variants, like the 1475-A which is a half moon shaft mount, which I may be able to make work with some extreme modifications potentially. I figured I’d reach out to check since I’ve had trouble finding 1475AY available anywhere.
Thanks for any assistance.
Welcome to the TechForum.
I am unsure of us carrying those in the future as stocking products. We may be able to special order the ones you want if we can meet the minimum quantity needed and the lead time.
I did locate a link of similar options and have them below.
White/Ivory knob options .250" shaft
Thank you
Ryan
