In our earlier posts, we covered key design guidelines for Silicon Carbide (SiC) in high-voltage power applications, provided a comparative overview of power semiconductor materials including Silicon (Si), Silicon Carbide (SiC), and Gallium Nitride (GaN), and discussed the importance of selecting the right semiconductor material in modern power conversion design.
This post takes a closer look at Design Considerations for Gallium Nitride (GaN). GaN products are rapidly emerging as a key wide-bandgap (WBG) semiconductor material, especially suited for high-frequency and high-power-density applications such as fast chargers, high-efficiency DC-DC converters, data centers, and 5G communication systems.
Key Design Considerations for GaN Power Design:
1. Gate Drive Requirements:
GaN HEMTs (high electron mobility transistors) typically operate between 6V and 7V, with low gate voltage tolerance (less than 10V). Overvoltage must be avoided using gate resistors and protection drivers such as eMode GaN.
2. No Body Diode:
GaN HEMTs lack the traditional body diode found in MOSFETs. It operates in synchronous rectification mode, reducing reverse recovery losses. Therefore, Dead-time must be well-optimized to prevent short-circuit damage.
3. EMI and PCB Layout:
Due to its high switching speeds (up to MHz level), GaN can cause strong electromagnetic interference (EMI). PCB layout should minimize parasitic inductance, use multi-layer boards, and ensure proper grounding.
4. Thermal Management:
While GaN has lower thermal conductivity than SiC, high-frequency switching and poor circuit layout leads to heat buildup. Use of thermal fillers, heat sinks, and compact packages like QFN or DFN and GDS is critical.
5. Short-Circuit Protection:
GaN HEMTs have limited short-circuit tolerance (typically <1µs). Therefore, fast overcurrent detection and shutdown mechanisms are essential to prevent component damage due to short circuits.
Conclusion
Gallium Nitride (GaN) is accelerating the development of power systems featuring high efficiency, high frequency, and high power density. With continued advancements in manufacturing processes and cost reduction, GaN is becoming increasingly suitable for applications such as fast charging, data centers, and RF communications. By addressing key design considerations such as gate drive control, EMI mitigation, and thermal management, GaN will play a vital role in enabling the next generation of compact and efficient power electronics.
Related Article
Design Do’s for SiC in High-Voltage Power Applications
Power Semiconductor Materials: Silicon vs. SiC vs. GaN Explained
Why Semiconductor Materials Matter in Power Design?
GaN Technology | DigiKey
Applicable Part Numbers
| 448-GS61004BMRXUSA1TR-ND,448-GS61004BMRXUSA1CT-ND,448-GS61004BMRXUSA1DKR-ND | GS61004BMRXUSA1 |
| 448-GS61008PMRXUSA1TR-ND,448-GS61008PMRXUSA1CT-ND,448-GS61008PMRXUSA1DKR-ND | GS61008PMRXUSA1 |
| 448-GS61008TMRXUSA1TR-ND,448-GS61008TMRXUSA1CT-ND,448-GS61008TMRXUSA1DKR-ND | GS61008TMRXUSA1 |
| 448-GS0650306LLMRXUMA1TR-ND,448-GS0650306LLMRXUMA1CT-ND,448-GS0650306LLMRXUMA1DKR-ND | GS0650306LLMRXUMA1 |
| 448-GS0650302LMRXUSA1TR-ND,448-GS0650302LMRXUSA1CT-ND,448-GS0650302LMRXUSA1DKR-ND | GS0650302LMRXUSA1 |
| 448-GS0650306LRMRXUSA1TR-ND,448-GS0650306LRMRXUSA1CT-ND,448-GS0650306LRMRXUSA1DKR-ND | GS0650306LRMRXUSA1 |
| 448-IGLT65R025D2AUMA1TR-ND,448-IGLT65R025D2AUMA1CT-ND,448-IGLT65R025D2AUMA1DKR-ND | IGLT65R025D2AUMA1 |
| 448-GS66504BMRXUSA1TR-ND,448-GS66504BMRXUSA1CT-ND,448-GS66504BMRXUSA1DKR-ND | GS66504BMRXUSA1 |
| 448-GS66506TMRXUSA1TR-ND,448-GS66506TMRXUSA1CT-ND,448-GS66506TMRXUSA1DKR-ND | GS66506TMRXUSA1 |
| 448-GS66516BMRXUSA1TR-ND,448-GS66516BMRXUSA1CT-ND,448-GS66516BMRXUSA1DKR-ND | GS66516BMRXUSA1 |
| 448-IGLR65R200D2XUMA1TR-ND,448-IGLR65R200D2XUMA1CT-ND,448-IGLR65R200D2XUMA1DKR-ND | IGLR65R200D2XUMA1 |
| 448-GS0650046LMRXUSA1TR-ND,448-GS0650046LMRXUSA1CT-ND,448-GS0650046LMRXUSA1DKR-ND | GS0650046LMRXUSA1 |
| 448-IGC033S10S1XTMA1TR-ND,448-IGC033S10S1XTMA1CT-ND,448-IGC033S10S1XTMA1DKR-ND | IGC033S10S1XTMA1 |
| 448-GS0650086LMRXUSA1TR-ND,448-GS0650086LMRXUSA1CT-ND,448-GS0650086LMRXUSA1DKR-ND | GS0650086LMRXUSA1 |
| 448-GS0650111LMRXUSA1TR-ND,448-GS0650111LMRXUSA1CT-ND,448-GS0650111LMRXUSA1DKR-ND | GS0650111LMRXUSA1 |
| 448-GS0650186LRMRXUSA1TR-ND,448-GS0650186LRMRXUSA1CT-ND,448-GS0650186LRMRXUSA1DKR-ND | GS0650186LRMRXUSA1 |
| 448-GS0650182LMRXUSA1TR-ND,448-GS0650182LMRXUSA1CT-ND,448-GS0650182LMRXUSA1DKR-ND | GS0650182LMRXUSA1 |
| 448-GS66502BMRXUSA1TR-ND,448-GS66502BMRXUSA1CT-ND,448-GS66502BMRXUSA1DKR-ND | GS66502BMRXUSA1 |
| 448-IGT65R025D2ATMA1TR-ND,448-IGT65R025D2ATMA1CT-ND,448-IGT65R025D2ATMA1DKR-ND | IGT65R025D2ATMA1 |
| 448-IGB110S101XTMA1TR-ND,448-IGB110S101XTMA1CT-ND,448-IGB110S101XTMA1DKR-ND | IGB110S101XTMA1 |
| 448-IGB070S10S1XTMA1CT-ND,448-IGB070S10S1XTMA1DKR-ND,448-IGB070S10S1XTMA1TR-ND | IGB070S10S1XTMA1 |
| 448-IGLR65R140D2XUMA1TR-ND,448-IGLR65R140D2XUMA1CT-ND,448-IGLR65R140D2XUMA1DKR-ND | IGLR65R140D2XUMA1 |
| 448-IGLD65R140D2AUMA1TR-ND,448-IGLD65R140D2AUMA1CT-ND,448-IGLD65R140D2AUMA1DKR-ND | IGLD65R140D2AUMA1 |
| 448-IGC025S08S1XTMA1TR-ND,448-IGC025S08S1XTMA1CT-ND,448-IGC025S08S1XTMA1DKR-ND | IGC025S08S1XTMA1 |
| 448-IGC033S101XTMA1TR-ND,448-IGC033S101XTMA1CT-ND,448-IGC033S101XTMA1DKR-ND | IGC033S101XTMA1 |
| 448-IGC037S12S1XTMA1CT-ND,448-IGC037S12S1XTMA1DKR-ND,448-IGC037S12S1XTMA1TR-ND | IGC037S12S1XTMA1 |
| 448-IGC019S06S1XTMA1TR-ND,448-IGC019S06S1XTMA1CT-ND,448-IGC019S06S1XTMA1DKR-ND | IGC019S06S1XTMA1 |
| 448-IGLD65R110D2AUMA1TR-ND,448-IGLD65R110D2AUMA1CT-ND,448-IGLD65R110D2AUMA1DKR-ND | IGLD65R110D2AUMA1 |
| 448-GS-065-011-6-L-MRTR-ND,448-GS-065-011-6-L-MRCT-ND,448-GS-065-011-6-L-MRDKR-ND | GS0650116LMRXUSA1 |
| 448-GS0650116LRMRXUSA1TR-ND,448-GS0650116LRMRXUSA1CT-ND,448-GS0650116LRMRXUSA1DKR-ND | GS0650116LRMRXUSA1 |
| 448-IGLD65R080D2AUMA1TR-ND,448-IGLD65R080D2AUMA1CT-ND,448-IGLD65R080D2AUMA1DKR-ND | IGLD65R080D2AUMA1 |
| 448-GS0650146LMRXUSA1TR-ND,448-GS0650146LMRXUSA1CT-ND,448-GS0650146LMRXUSA1DKR-ND | GS0650146LMRXUSA1 |
| 448-IGT65R055D2ATMA1TR-ND,448-IGT65R055D2ATMA1CT-ND,448-IGT65R055D2ATMA1DKR-ND | IGT65R055D2ATMA1 |
| 448-IGLT65R055D2ATMA1TR-ND,448-IGLT65R055D2ATMA1CT-ND,448-IGLT65R055D2ATMA1DKR-ND | IGLT65R055D2ATMA1 |
| 448-IGLD65R055D2AUMA1TR-ND,448-IGLD65R055D2AUMA1CT-ND,448-IGLD65R055D2AUMA1DKR-ND | IGLD65R055D2AUMA1 |
| 448-IGOT65R055D2AUMA1TR-ND,448-IGOT65R055D2AUMA1CT-ND,448-IGOT65R055D2AUMA1DKR-ND | IGOT65R055D2AUMA1 |
| 448-IGT65R045D2ATMA1TR-ND,448-IGT65R045D2ATMA1CT-ND,448-IGT65R045D2ATMA1DKR-ND | IGT65R045D2ATMA1 |
| 448-IGLT65R045D2ATMA1TR-ND,448-IGLT65R045D2ATMA1CT-ND,448-IGLT65R045D2ATMA1DKR-ND | IGLT65R045D2ATMA1 |
| 448-IGLT65R035D2ATMA1TR-ND,448-IGLT65R035D2ATMA1CT-ND,448-IGLT65R035D2ATMA1DKR-ND | IGLT65R035D2ATMA1 |
| 448-IGT65R035D2ATMA1TR-ND,448-IGT65R035D2ATMA1CT-ND,448-IGT65R035D2ATMA1DKR-ND | IGT65R035D2ATMA1 |
| 448-IGOT65R025D2AUMA1TR-ND,448-IGOT65R025D2AUMA1CT-ND,448-IGOT65R025D2AUMA1DKR-ND | IGOT65R025D2AUMA1 |
| 448-GS66508BMRXUSA1TR-ND,448-GS66508BMRXUSA1CT-ND,448-GS66508BMRXUSA1DKR-ND | GS66508BMRXUSA1 |
| 448-GS66516TMRXUSA1TR-ND,448-GS66516TMRXUSA1CT-ND,448-GS66516TMRXUSA1DKR-ND | GS66516TMRXUSA1 |
| 448-GS0650112LMRXUSA1TR-ND,448-GS0650112LMRXUSA1CT-ND,448-GS0650112LMRXUSA1DKR-ND | GS0650112LMRXUSA1 |
| 448-GS-065-014-6-LR-MRTR-ND,448-GS-065-014-6-LR-MRCT-ND,448-GS-065-014-6-LR-MRDKR-ND | GS0650146LRMRXUSA1 |
| 448-IGLR70R270D2SXUMA1TR-ND,448-IGLR70R270D2SXUMA1CT-ND,448-IGLR70R270D2SXUMA1DKR-ND | IGLR70R270D2SXUMA1 |
| 448-IGB110S10S1XTMA1TR-ND,448-IGB110S10S1XTMA1CT-ND,448-IGB110S10S1XTMA1DKR-ND | IGB110S10S1XTMA1 |
| 448-IGLR65R270D2XUMA1TR-ND,448-IGLR65R270D2XUMA1CT-ND,448-IGLR65R270D2XUMA1DKR-ND | IGLR65R270D2XUMA1 |
| 448-IGLR70R200D2SXUMA1TR-ND,448-IGLR70R200D2SXUMA1CT-ND,448-IGLR70R200D2SXUMA1DKR-ND | IGLR70R200D2SXUMA1 |
| 448-IGLR70R140D2SXUMA1TR-ND,448-IGLR70R140D2SXUMA1CT-ND,448-IGLR70R140D2SXUMA1DKR-ND | IGLR70R140D2SXUMA1 |
| 448-IGL65R140D2XUMA1TR-ND,448-IGL65R140D2XUMA1CT-ND,448-IGL65R140D2XUMA1DKR-ND | IGL65R140D2XUMA1 |
| 448-IGT65R140D2ATMA1TR-ND,448-IGT65R140D2ATMA1CT-ND,448-IGT65R140D2ATMA1DKR-ND | IGT65R140D2ATMA1 |
| 448-IGL65R110D2XUMA1TR-ND,448-IGL65R110D2XUMA1CT-ND,448-IGL65R110D2XUMA1DKR-ND | IGL65R110D2XUMA1 |
| 448-IGLT65R110D2ATMA1TR-ND,448-IGLT65R110D2ATMA1CT-ND,448-IGLT65R110D2ATMA1DKR-ND | IGLT65R110D2ATMA1 |
| 448-IGL65R080D2XUMA1TR-ND,448-IGL65R080D2XUMA1CT-ND,448-IGL65R080D2XUMA1DKR-ND | IGL65R080D2XUMA1 |
| 448-IGL65R055D2XUMA1TR-ND,448-IGL65R055D2XUMA1CT-ND,448-IGL65R055D2XUMA1DKR-ND | IGL65R055D2XUMA1 |
| 448-IGOT65R045D2AUMA1TR-ND,448-IGOT65R045D2AUMA1CT-ND,448-IGOT65R045D2AUMA1DKR-ND | IGOT65R045D2AUMA1 |
| 448-IGOT65R035D2AUMA1TR-ND,448-IGOT65R035D2AUMA1CT-ND,448-IGOT65R035D2AUMA1DKR-ND | IGOT65R035D2AUMA1 |
| 448-GS0650046LTRXUMA1TR-ND | GS0650046LTRXUMA1 |
| 448-GS-065-004-1-L-TR-ND | GS-065-004-1-L-TR |
| 448-GS0650086LTRXUMA1TR-ND | GS0650086LTRXUMA1 |
| 448-GS0650116LTRXUMA1TR-ND | GS0650116LTRXUMA1 |
| 448-GS0650116LRTRXUMA1TR-ND | GS0650116LRTRXUMA1 |
| 448-GS0650111LTRXUMA1TR-ND | GS0650111LTRXUMA1 |
| 448-GS61004BTRXUMA1TR-ND | GS61004BTRXUMA1 |
| 448-GS0650112LTRXUMA1TR-ND | GS0650112LTRXUMA1 |
| 448-GS-065-008-1-L-TR-ND | GS-065-008-1-L-TR |
| 448-GS0650146LTRXUMA1TR-ND | GS0650146LTRXUMA1 |
| 448-GS0650146LRTRXUMA1TR-ND | GS0650146LRTRXUMA1 |
| 448-GS0650186LRTRXUMA1TR-ND | GS0650186LRTRXUMA1 |
| 448-GS-065-004-1-L-MRTR-ND,448-GS-065-004-1-L-MRCT-ND,448-GS-065-004-1-L-MRDKR-ND | GS-065-004-1-L-MR |
| 448-GS0650182LTRXUMA1TR-ND | GS0650182LTRXUMA1 |
| 448-GS61008PTRXUMA1TR-ND | GS61008PTRXUMA1 |
| 448-GS61008TTRXUMA1TR-ND | GS61008TTRXUMA1 |
| 448-GS0650306LLTRXUMA1TR-ND | GS0650306LLTRXUMA1 |
| 448-GS-065-008-1-L-MRTR-ND,448-GS-065-008-1-L-MRCT-ND,448-GS-065-008-1-L-MRDKR-ND | GS-065-008-1-L-MR |
| 448-GS0650302LTRXUMA1TR-ND | GS0650302LTRXUMA1 |
| 448-GS0650306LRTRXUMA1TR-ND | GS0650306LRTRXUMA1 |
| 448-GS66502BTRXUMA1TR-ND | GS66502BTRXUMA1 |
| 448-GS66504BTRXUMA1TR-ND | GS66504BTRXUMA1 |
| 448-GS66506TTRXUMA1TR-ND | GS66506TTRXUMA1 |
| 448-GS66508BTRXUMA1TR-ND | GS66508BTRXUMA1 |
| 448-GS66516TTRXUMA1TR-ND | GS66516TTRXUMA1 |
| 448-GS66516BTRXUMA1TR-ND | GS66516BTRXUMA1 |
| 448-GS-065-060-5-B-A-TR-ND | GS-065-060-5-B-A-TR |
| 917-1200-2-ND,917-1200-1-ND,917-1200-6-ND | EPC2203 |
| 917-1153-2-ND,917-1153-1-ND,917-1153-6-ND | EPC2040 |
| 917-EPC2070TR-ND,917-EPC2070CT-ND,917-EPC2070DKR-ND | EPC2070 |
| 917-1137-2-ND,917-1137-1-ND,917-1137-6-ND | EPC2037 |
| 917-1138-2-ND,917-1138-1-ND,917-1138-6-ND | EPC2038 |
| 917-1099-2-ND,917-1099-1-ND,917-1099-6-ND | EPC2035 |
| 917-1100-2-ND,917-1100-1-ND,917-1100-6-ND | EPC2036 |
| 917-1082-2-ND,917-1082-1-ND,917-1082-6-ND | EPC2014C |
| 917-1202-2-ND,917-1202-1-ND,917-1202-6-ND | EPC2052 |
| 917-1206-2-ND,917-1206-1-ND,917-1206-6-ND | EPC2054 |
| 917-1213-2-ND,917-1213-1-ND,917-1213-6-ND | EPC2214 |
| 917-EPC2252TR-ND,917-EPC2252CT-ND,917-EPC2252DKR-ND | EPC2252 |
| 917-1086-2-ND,917-1086-1-ND,917-1086-6-ND | EPC8010 |
| 917-EPC2207TR-ND,917-EPC2207CT-ND,917-EPC2207DKR-ND | EPC2207 |
| 917-EPC2204TR-ND,917-EPC2204CT-ND,917-EPC2204DKR-ND | EPC2204 |
| 917-EPC2055TR-ND,917-EPC2055CT-ND,917-EPC2055DKR-ND | EPC2055 |
| 917-1084-2-ND,917-1084-1-ND,917-1084-6-ND | EPC2012C |
| 917-1072-2-ND,917-1072-1-ND,917-1072-6-ND | EPC8004 |
| 917-1118-2-ND,917-1118-1-ND,917-1118-6-ND | EPC8002 |
| 917-EPC2059TR-ND,917-EPC2059CT-ND,917-EPC2059DKR-ND | EPC2059 |
| 917-EPC2619TR-ND,917-EPC2619CT-ND,917-EPC2619DKR-ND | EPC2619 |
| 917-1078-2-ND,917-1078-1-ND,917-1078-6-ND | EPC8009 |
| 917-1087-2-ND,917-1087-1-ND,917-1087-6-ND | EPC2019 |
| 917-EPC2306TR-ND,917-EPC2306CT-ND,917-EPC2306DKR-ND | EPC2306 |
| 917-EPC2307TR-ND,917-EPC2307CT-ND,917-EPC2307DKR-ND | EPC2307 |
| 917-1212-2-ND,917-1212-1-ND,917-1212-6-ND | EPC2206 |
| 917-1218-2-ND,917-1218-1-ND,917-1218-6-ND | EPC2215 |
| 917-EPC2067TR-ND,917-EPC2067CT-ND,917-EPC2067DKR-ND | EPC2067 |
| 917-EPC2306ENGRTTR-ND,917-EPC2306ENGRTCT-ND,917-EPC2306ENGRTDKR-ND | EPC2306ENGRT |
| 917-EPC2308ENGRTTR-ND,917-EPC2308ENGRTCT-ND,917-EPC2308ENGRTDKR-ND | EPC2308ENGRT |
| 917-EPC2050TR-ND,917-EPC2050CT-ND,917-EPC2050DKR-ND | EPC2050 |
| 1727-GAN080-650EBEZTR-ND,1727-GAN080-650EBEZCT-ND,1727-GAN080-650EBEZDKR-ND | GAN080-650EBEZ |
| 917-EPC2071TR-ND,917-EPC2071CT-ND,917-EPC2071DKR-ND | EPC2071 |
| 917-EPC2307ENGRTTR-ND,917-EPC2307ENGRTCT-ND,917-EPC2307ENGRTDKR-ND | EPC2307ENGRT |
| 917-EPC2066TR-ND,917-EPC2066CT-ND,917-EPC2066DKR-ND | EPC2066 |
| 917-EPC2305TR-ND,917-EPC2305CT-ND,917-EPC2305DKR-ND | EPC2305 |
| 917-1151-2-ND,917-1151-1-ND,917-1151-6-ND | EPC2031 |
| 917-EPC2304TR-ND,917-EPC2304CT-ND,917-EPC2304DKR-ND | EPC2304 |
| 1707-TP65H015G5WS-ND | TP65H015G5WS |
| 4107-EPC7014UBC-ND | EPC7014UBC |
| 917-1224-2-ND,917-1224-1-ND,917-1224-6-ND | EPC2216 |
| 917-EPC2219TR-ND,917-EPC2219CT-ND,917-EPC2219DKR-ND | EPC2219 |
| 917-EPC2057TR-ND,917-EPC2057CT-ND,917-EPC2057DKR-ND | EPC2057 |
| 917-EPC2044TR-ND,917-EPC2044CT-ND,917-EPC2044DKR-ND | EPC2044 |
| 1727-GAN190-650FBEZTR-ND,1727-GAN190-650FBEZCT-ND,1727-GAN190-650FBEZDKR-ND | GAN190-650FBEZ |
| 1727-GAN7R0-150LBEZTR-ND,1727-GAN7R0-150LBEZCT-ND,1727-GAN7R0-150LBEZDKR-ND | GAN7R0-150LBEZ |
| 1727-GAN190-650EBEZTR-ND,1727-GAN190-650EBEZCT-ND,1727-GAN190-650EBEZDKR-ND | GAN190-650EBEZ |
| 917-EPC2065TR-ND,917-EPC2065CT-ND,917-EPC2065DKR-ND | EPC2065 |
| 1727-GAN3R2-100CBEAZTR-ND,1727-GAN3R2-100CBEAZCT-ND,1727-GAN3R2-100CBEAZDKR-ND | GAN3R2-100CBEAZ |
| 1707-TP65H150BG4JSG-TR-ND,1707-TP65H150BG4JSG-TRCT-ND,1707-TP65H150BG4JSG-TRDKR-ND | TP65H150BG4JSG-TR |
| 917-EPC2308TR-ND,917-EPC2308CT-ND,917-EPC2308DKR-ND | EPC2308 |
| 1727-GANE3R9-150QBAZTR-ND,1727-GANE3R9-150QBAZCT-ND,1727-GANE3R9-150QBAZDKR-ND | GANE3R9-150QBAZ |
| 1707-TP65H100G4PS-ND | TP65H100G4PS |
| 1707-TP65H150G4PS-ND | TP65H150G4PS |
| 1707-TP65H070G4QS-TR-ND,1707-TP65H070G4QS-TRCT-ND,1707-TP65H070G4QS-TRDKR-ND | TP65H070G4QS-TR |
| 1707-TP65H070G4PS-ND | TP65H070G4PS |
| 1707-TP65H070G4RS-TR-ND,1707-TP65H070G4RS-TRCT-ND,1707-TP65H070G4RS-TRDKR-ND | TP65H070G4RS-TR |
| 1727-GAN111-650WSBQ-ND | GAN111-650WSBQ |
| 1707-TP65H070LSG-TR-ND,1707-TP65H070LSG-CT-ND,1707-TP65H070LSG-DKR-ND | TP65H070LSG-TR |
| 1707-TP65H070G4LSG-TR-ND,1707-TP65H070G4LSG-TRCT-ND,1707-TP65H070G4LSG-TRDKR-ND | TP65H070G4LSG-TR |
| 1707-TP65H070G4LSGB-TR-ND,1707-TP65H070G4LSGB-TRCT-ND,1707-TP65H070G4LSGB-TRDKR-ND | TP65H070G4LSGB-TR |
| 1727-GAN039-650NTBJTR-ND,1727-GAN039-650NTBJCT-ND,1727-GAN039-650NTBJDKR-ND | GAN039-650NTBJ |
| 917-EPC2234TR-ND,917-EPC2234CT-ND,917-EPC2234DKR-ND | EPC2234 |
| 1707-TP65H050G4BS-ND | TP65H050G4BS |
| 1707-TP65H050G4WS-ND | TP65H050G4WS |
| 1707-TP65H035G4QSTR-ND,1707-TP65H035G4QSCT-ND,1707-TP65H035G4QSDKR-ND | TP65H035G4QS |
| 917-EPC2069TR-ND,917-EPC2069CT-ND,917-EPC2069DKR-ND | EPC2069 |
| 1727-GAN140-650FBEZTR-ND,1727-GAN140-650FBEZCT-ND,1727-GAN140-650FBEZDKR-ND | GAN140-650FBEZ |
| 1707-TP65H300G4LSG-TR-ND,1707-TP65H300G4LSG-TRCT-ND,1707-TP65H300G4LSG-TRDKR-ND | TP65H300G4LSG-TR |
| 1707-TP65H150G4LSG-ND,1707-TP65H150G4LSGCT-ND,1707-TP65H150G4LSGDKR-ND | TP65H150G4LSG |
| 1707-TP65H150G4LSG-TR-ND,1707-TP65H150G4LSG-TRCT-ND,1707-TP65H150G4LSG-TRDKR-ND | TP65H150G4LSG-TR |
| 1727-GAN140-650EBEZTR-ND,1727-GAN140-650EBEZCT-ND,1727-GAN140-650EBEZDKR-ND | GAN140-650EBEZ |
| 1707-TP65H070LDG-TR-ND,1707-TP65H070LDG-TRCT-ND,1707-TP65H070LDG-TRDKR-ND | TP65H070LDG-TR |
| 1727-GANB8R0-040CBAZTR-ND,1727-GANB8R0-040CBAZCT-ND,1727-GANB8R0-040CBAZDKR-ND | GANB8R0-040CBAZ |
| 1707-TP65H480G4JSGB-TR-ND,1707-TP65H480G4JSGB-TRCT-ND,1707-TP65H480G4JSGB-TRDKR-ND | TP65H480G4JSGB-TR |
| 1707-TP65H300G4LSGB-TR-ND,1707-TP65H300G4LSGB-TRCT-ND,1707-TP65H300G4LSGB-TRDKR-ND | TP65H300G4LSGB-TR |
| 1707-TP65H300G4JSGB-TR-ND,1707-TP65H300G4JSGB-TRCT-ND,1707-TP65H300G4JSGB-TRDKR-ND | TP65H300G4JSGB-TR |
| 1514-CDF56G6511NTR13PBFREETR-ND,1514-CDF56G6511NTR13PBFREECT-ND,1514-CDF56G6511NTR13PBFREEDKR-ND | CDF56G6511N TR13 PBFREE |
| 1514-CCSPG1060NTRPBFREETR-ND,1514-CCSPG1060NTRPBFREECT-ND,1514-CCSPG1060NTRPBFREEDKR-ND | CCSPG1060N TR PBFREE |
| 4296-WI71100TR-ND,4296-WI71100TRCT-ND,4296-WI71100TRDKR-ND | WI71100TR |
| 1514-CCSPG1560NTRPBFREETR-ND,1514-CCSPG1560NTRPBFREECT-ND,1514-CCSPG1560NTRPBFREEDKR-ND | CCSPG1560N TR PBFREE |
| 4296-WI71060TR-ND,4296-WI71060TRCT-ND,4296-WI71060TRDKR-ND | WI71060TR |
| 1514-CCSPG1510NTRPBFREETR-ND,1514-CCSPG1510NTRPBFREECT-ND,1514-CCSPG1510NTRPBFREEDKR-ND | CCSPG1510N TR PBFREE |
| 1514-CDFG6558NTR13PBFREETR-ND,1514-CDFG6558NTR13PBFREECT-ND,1514-CDFG6558NTR13PBFREEDKR-ND | CDFG6558N TR13 PBFREE |
| 1707-TP65H050G4QS-TR-ND,1707-TP65H050G4QS-TRCT-ND,1707-TP65H050G4QS-TRDKR-ND | TP65H050G4QS-TR |
| 1707-TP65H050G4YS-ND | TP65H050G4YS |
| 4025-GPI65005DF68TR-ND | GPI65005DF68 |
| 4025-GPI65005DFTR-ND | GPI65005DF |
| 4025-GPI65008DF68TR-ND | GPI65008DF68 |
| 4025-GPI90007DF88TR-ND | GPI90007DF88 |
| 4025-GPI65010DF56TR-ND | GPI65010DF56 |
| 4768-CGD65B240SH2TR-ND,4768-CGD65B240SH2CT-ND,4768-CGD65B240SH2DKR-ND | CGD65B240SH2 |
| 4768-CGD65B200S2-T13TR-ND,4768-CGD65B200S2-T13CT-ND,4768-CGD65B200S2-T13DKR-ND | CGD65B200S2-T13 |
| 4025-GPI90010DF88TR-ND | GPI90010DF88 |
| 917-EPC2367ENGRTTR-ND,917-EPC2367ENGRTCT-ND,917-EPC2367ENGRTDKR-ND | EPC2367ENGRT |
| 4768-CGD65B130SH2TR-ND,4768-CGD65B130SH2CT-ND,4768-CGD65B130SH2DKR-ND | CGD65B130SH2 |
| 4768-CGD65B130S2-T13TR-ND,4768-CGD65B130S2-T13CT-ND,4768-CGD65B130S2-T13DKR-ND | CGD65B130S2-T13 |
| 4025-GPI65015TO-ND | GPI65015TO |
| 4025-GPI65015DFNTR-ND | GPI65015DFN |
| 4768-CGD65A130SH2TR-ND,4768-CGD65A130SH2CT-ND,4768-CGD65A130SH2DKR-ND | CGD65A130SH2 |
| 4768-CGD65A130S2-T13TR-ND,4768-CGD65A130S2-T13CT-ND,4768-CGD65A130S2-T13DKR-ND | CGD65A130S2-T13 |
| 4768-CGD65A055SH2TR-ND,4768-CGD65A055SH2CT-ND,4768-CGD65A055SH2DKR-ND | CGD65A055SH2 |
| 4768-CGD65A055S2-T07TR-ND,4768-CGD65A055S2-T07CT-ND,4768-CGD65A055S2-T07DKR-ND | CGD65A055S2-T07 |
| 4025-GPI65007DF88TR-ND | GPI65007DF88 |
| 1707-TP65H035G4WSQA-ND | TP65H035G4WSQA |
| 4107-EPC7014UBSH-ND | EPC7014UBSH |
| 4025-GPI65007DF56TR-ND | GPI65007DF56 |
| 4025-GPI65008DF56TR-ND | GPI65008DF56 |
| 4025-GPI65030DFNTR-ND | GPI65030DFN |
| 4025-GPI65030TO5LTR-ND | GPI65030TO5L |
| 4025-GPI65060DFCTR-ND | GPI65060DFC |
| 5318-AMTP65H150G4LSGB-ND | AMTP65H150G4LSGB |
| 917-1201-2-ND,917-1201-1-ND,917-1201-6-ND | EPC2051 |
| 917-EPC2204ATR-ND,917-EPC2204ACT-ND,917-EPC2204ADKR-ND | EPC2204A |
| 917-EPC2218ATR-ND,917-EPC2218ACT-ND,917-EPC2218ADKR-ND | EPC2218A |
| 917-EPC2302TR-ND,917-EPC2302CT-ND,917-EPC2302DKR-ND | EPC2302 |
| 1727-GANB4R8-040CBAZTR-ND,1727-GANB4R8-040CBAZCT-ND,1727-GANB4R8-040CBAZDKR-ND | GANB4R8-040CBAZ |
| 497-SGT120R65ALTR-ND,497-SGT120R65ALCT-ND,497-SGT120R65ALDKR-ND | SGT120R65AL |
| 917-EPC2367TR-ND,917-EPC2367CT-ND,917-EPC2367DKR-ND | EPC2367 |
| 917-EPC2361TR-ND,917-EPC2361CT-ND,917-EPC2361DKR-ND | EPC2361 |
| 1707-TP65H480G4JSG-ND | TP65H480G4JSG |
| 1707-TP65H100G4LSGB-TR-ND,1707-TP65H100G4LSGB-TRCT-ND,1707-TP65H100G4LSGB-TRDKR-ND | TP65H100G4LSGB-TR |
| 917-EPC2304ENGRTTR-ND,917-EPC2304ENGRTCT-ND,917-EPC2304ENGRTDKR-ND | EPC2304ENGRT |
| 4025-GPI65060DFNTR-ND | GPI65060DFN |
| 4025-GPIHV30SB5L-ND | GPIHV30SB5L |
| 4025-GPIXV30DFN-ND | GPIXV30DFN |
| 4025-GPIHV5DKTR-ND | GPIHV5DK |
| 4025-GPIHV10DKTR-ND | GPIHV10DK |
| 4025-GPIHV7DKTR-ND | GPIHV7DK |
| 4025-GPI90005DF88TR-ND | GPI90005DF88 |
| 5318-AMTP65H150G4PS-ND | AMTP65H150G4PS |
| 576-1206-2-ND,576-1206-1-ND,576-1206-6-ND | MIC4428YM-TR |
| 576-1204-2-ND,576-1204-1-ND,576-1204-6-ND | MIC4427YM-TR |
| 576-1525-5-ND | MIC4427YM |
| 576-1202-2-ND,576-1202-1-ND,576-1202-6-ND | MIC4426YM-TR |
| TC4427ACOA713TR-ND,TC4427ACOA713CT-ND,TC4427ACOA713DKR-ND | TC4427ACOA713 |
| TC426COA713TR-ND,TC426COA713CT-ND,TC426COA713DKR-ND | TC426COA713 |
| TC4428EOA713TR-ND,TC4428EOA713CT-ND,TC4428EOA713DKR-ND | TC4428EOA713 |
| TC4426AVOA713TR-ND,TC4426AVOA713CT-ND,TC4426AVOA713DKR-ND | TC4426AVOA713 |
| 576-1198-ND | MIC4424YM |
| TC4427CPA-ND | TC4427CPA |
| MD1822K6-GTR-ND,MD1822K6-GCT-ND,MD1822K6-GDKR-ND | MD1822K6-G |
| 5656-IX4427NTR-ND,5656-IX4427NTRCT-ND,5656-IX4427NTRDKR-ND | IX4427NTR |
| 5656-IX4426NTR-ND,5656-IX4426NTRCT-ND,5656-IX4426NTRDKR-ND | IX4426NTR |
| TC4424AVOA713TR-ND,TC4424AVOA713CT-ND,TC4424AVOA713DKR-ND | TC4424AVOA713 |
| 5656-IX4427MTR-ND,5656-IX4427MTRCT-ND,5656-IX4427MTRDKR-ND | IX4427MTR |
| TC1413NEOA713TR-ND,TC1413NEOA713CT-ND,TC1413NEOA713DKR-ND | TC1413NEOA713 |
| 576-1448-ND | MIC4124YME |
| 488-NCP51820AMNTWGTR-ND,488-NCP51820AMNTWGCT-ND,488-NCP51820AMNTWGDKR-ND | NCP51820AMNTWG |
| 917-UP1966ETR-ND,917-UP1966ECT-ND,917-UP1966EDKR-ND | UP1966E |
| 448-2EDF7275FXUMA2TR-ND,448-2EDF7275FXUMA2CT-ND,448-2EDF7275FXUMA2DKR-ND | 2EDF7275FXUMA2 |
| MD1810K6-GTR-ND,MD1810K6-GCT-ND,MD1810K6-GDKR-ND | MD1810K6-G |
| TC4432EOA713TR-ND,TC4432EOA713CT-ND,TC4432EOA713DKR-ND | TC4432EOA713 |
| TC4431EOA-ND | TC4431EOA |
| TC4431VOA713TR-ND,TC4431VOA713CT-ND,TC4431VOA713DKR-ND | TC4431VOA713 |
| 296-50208-2-ND,296-50208-1-ND,296-50208-6-ND | LMG1020YFFR |
| TC4468COE713TR-ND,TC4468COE713CT-ND,TC4468COE713DKR-ND | TC4468COE713 |
| 150-TC4469COE713TR-ND,150-TC4469COE713CT-ND,150-TC4469COE713DKR-ND | TC4469COE713 |
| TC4468COE-ND | TC4468COE |
| TC4469COE-ND | TC4469COE |
| 296-50209-2-ND,296-50209-1-ND,296-50209-6-ND | LMG1020YFFT |
| TC4468EOE-ND | TC4468EOE |
| 505-LT8418ACBZ-R7TR-ND,505-LT8418ACBZ-R7CT-ND,505-LT8418ACBZ-R7DKR-ND | LT8418ACBZ-R7 |
| MAX627CSA+TTR-ND,MAX627CSA+TCT-ND,MAX627CSA+TDKR-ND | MAX627CSA+T |
| MAX626CSA+TTR-ND,MAX626CSA+TCT-ND,MAX626CSA+TDKR-ND | MAX626CSA+T |
| EL7457CLZ-T7TR-ND,EL7457CLZ-T7CT-ND,EL7457CLZ-T7DKR-ND | EL7457CLZ-T7 |
| EL7457CUZ-ND | EL7457CUZ |
| 296-UCC27424MDGNREPTR-ND,296-UCC27424MDGNREPCT-ND,296-UCC27424MDGNREPDKR-ND | UCC27424MDGNREP |
| MAX4428ESA±ND | MAX4428ESA+ |
| 296-LMG1025QDEETQ1TR-ND,296-LMG1025QDEETQ1CT-ND,296-LMG1025QDEETQ1DKR-ND | LMG1025QDEETQ1 |
| 296-12120-5-ND | UC3708N |
| TC4427MJA-ND | TC4427MJA |
| 448-2EDN7534FXTMA1TR-ND,448-2EDN7534FXTMA1CT-ND,448-2EDN7534FXTMA1DKR-ND | 2EDN7534FXTMA1 |
| 1EDN8511BXUSA1TR-ND,1EDN8511BXUSA1CT-ND,1EDN8511BXUSA1DKR-ND | 1EDN8511BXUSA1 |
| 1EDN7511BXUSA1TR-ND,1EDN7511BXUSA1CT-ND,1EDN7511BXUSA1DKR-ND | 1EDN7511BXUSA1 |
| MCP14A0052T-E/CHTR-ND,MCP14A0052T-E/CHCT-ND,MCP14A0052T-E/CHDKR-ND | MCP14A0052T-E/CH |
| 497-14958-2-ND,497-14958-1-ND,497-14958-6-ND | PM8841D |
| 5656-IX4428N-ND | IX4428N |
| MCP14A0152T-E/CHTR-ND,MCP14A0152T-E/CHCT-ND,MCP14A0152T-E/CHDKR-ND | MCP14A0152T-E/CH |
| 448-2EDN7534BXTSA1TR-ND,448-2EDN7534BXTSA1CT-ND,448-2EDN7534BXTSA1DKR-ND | 2EDN7534BXTSA1 |
| 5656-IX4427N-ND | IX4427N |
| 5656-IX4426N-ND | IX4426N |
| IX4340NE-ND | IX4340NE |
| 296-31999-2-ND,296-31999-1-ND,296-31999-6-ND | UCC27324DGNR |
| 296-27156-2-ND,296-27156-1-ND,296-27156-6-ND | UCC27324DR |
| 296-41811-2-ND,296-41811-1-ND,296-41811-6-ND | UCC37324DR |
| 296-41799-2-ND,296-41799-1-ND,296-41799-6-ND | UCC27424DGNR |
| 5656-IX4426MTR-ND,5656-IX4426MTRCT-ND,5656-IX4426MTRDKR-ND | IX4426MTR |
| 5656-IX4428MTR-ND,5656-IX4428MTRCT-ND,5656-IX4428MTRDKR-ND | IX4428MTR |
| MCP14A0154-E/MS-ND | MCP14A0154-E/MS |
| 296-48798-2-ND,296-48798-1-ND,296-48798-6-ND | UCC27321DR |
| 296-41796-2-ND,296-41796-1-ND,296-41796-6-ND,2156-UCC27322DGNR-ND | UCC27322DGNR |
| 296-39526-2-ND,296-39526-1-ND,296-39526-6-ND | UCC27424DR |
| 296-UCC37321DRTR-ND,296-UCC37321DRCT-ND,296-UCC37321DRDKR-ND | UCC37321DR |
| 576-3377-5-ND | MIC4427YMM |
| 576-1547-2-ND,576-1547-1-ND,576-1547-6-ND | MIC4427YMM-TR |
| 576-1523-5-ND | MIC4426YM |
| 576-3406-5-ND | MIC4428YM |
| 2156-UCC27423P-ND,296-15866-5-ND | UCC27423P |
| 2156-UCC27425P-ND,296-15872-5-ND | UCC27425P |
| 296-UCC27425DRTR-ND,296-UCC27425DRCT-ND,296-UCC27425DRDKR-ND | UCC27425DR |
| TC4427ACOA-ND | TC4427ACOA |
| TC4428ACOA-ND | TC4428ACOA |
| 150-MD1211LG-GTR-ND,150-MD1211LG-GCT-ND,150-MD1211LG-GDKR-ND | MD1211LG-G |
| 296-23486-2-ND,296-23486-1-ND,296-23486-6-ND | UCC27324QDRQ1 |
| TC1427COA713TR-ND,TC1427COA713CT-ND,TC1427COA713DKR-ND | TC1427COA713 |
| 296-15869-5-ND | UCC27424P |
| 5656-IX4310TTR-ND,5656-IX4310TTRCT-ND | IX4310TTR |
| TC4426ACPA-ND | TC4426ACPA |
| TC1427CPA-ND | TC1427CPA |
| 576-1445-ND | MIC4120YME |
| MIC4120YME-TR-ND,MIC4120YME-CT-ND,MIC4120YME-DKR-ND | MIC4120YME-TR |
| TC427EOA713TR-ND,TC427EOA713CT-ND,TC427EOA713DKR-ND | TC427EOA713 |
| TC427EOA-ND | TC427EOA |
| TC4428AEOA713TR-ND,TC4428AEOA713CT-ND,TC4428AEOA713DKR-ND | TC4428AEOA713 |
| TC4428VOA713TR-ND,TC4428VOA713CT-ND,TC4428VOA713DKR-ND | TC4428VOA713 |
| TC4428EOA-ND | TC4428EOA |
| TC4427COA-ND | TC4427COA |
| TC4426EOA-ND | TC4426EOA |
| 2EDL05I06PJXUMA1TR-ND,2EDL05I06PJXUMA1CT-ND,2EDL05I06PJXUMA1DKR-ND | 2EDL05I06PJXUMA1 |
| TC4427COA713TR-ND,TC4427COA713CT-ND,TC4427COA713DKR-ND | TC4427COA713 |
| TC4427AVOA713TR-ND,TC4427AVOA713CT-ND,TC4427AVOA713DKR-ND | TC4427AVOA713 |
| TC4426EOA713TR-ND,TC4426EOA713CT-ND,TC4426EOA713DKR-ND | TC4426EOA713 |
| TC4426ACOA713TR-ND,TC4426ACOA713CT-ND,TC4426ACOA713DKR-ND | TC4426ACOA713 |
| TC4426COA713TR-ND,TC4426COA713CT-ND,TC4426COA713DKR-ND | TC4426COA713 |
| TC4427AEOA713TR-ND,TC4427AEOA713CT-ND,TC4427AEOA713DKR-ND | TC4427AEOA713 |
| TC4427AEOA-ND | TC4427AEOA |
| TC4426AEOA-ND | TC4426AEOA |
| TC4427EOA713TR-ND,TC4427EOA713CT-ND,TC4427EOA713DKR-ND | TC4427EOA713 |
| TC4428AEOA-ND | TC4428AEOA |
| TC4427EOA-ND | TC4427EOA |
| TC4426COA-ND | TC4426COA |
| TC4426ACOA-ND | TC4426ACOA |
| 296-12533-5-ND | UCC27324P |
| TC426CPA-ND | TC426CPA |
| 576-1203-ND | MIC4426YN |
| 576-1189-2-ND,576-1189-1-ND,576-1189-6-ND | MIC4420YM-TR |
| 576-1546-2-ND,576-1546-1-ND,576-1546-6-ND | MIC4424YM-TR |
| 576-3376-5-ND | MIC4420YM |
| TC4428AEPA-ND | TC4428AEPA |
| TC4427AEPA-ND | TC4427AEPA |
| TC4426EPA-ND | TC4426EPA |
| TC4428EPA-ND | TC4428EPA |
| TC4427EPA-ND | TC4427EPA |
| TC4427ACPA-ND | TC4427ACPA |
| TC4426CPA-ND | TC4426CPA |
| TC4420COA713TR-ND,TC4420COA713CT-ND,TC4420COA713DKR-ND | TC4420COA713 |
| TC4420COA-ND | TC4420COA |
| TC4420EOA713TR-ND,TC4420EOA713CT-ND,TC4420EOA713DKR-ND | TC4420EOA713 |
| TC4420EOA-ND | TC4420EOA |
| TC4427EUA713TR-ND,TC4427EUA713CT-ND,TC4427EUA713DKR-ND | TC4427EUA713 |
| 448-TLF11251LDXUMA1TR-ND,448-TLF11251LDXUMA1CT-ND,448-TLF11251LDXUMA1DKR-ND | TLF11251LDXUMA1 |
| 5656-IX4428NTR-ND,5656-IX4428NTRCT-ND,5656-IX4428NTRDKR-ND | IX4428NTR |
| TC4424AVOA-ND | TC4424AVOA |
| 448-TLF11251EPXUMA1TR-ND,448-TLF11251EPXUMA1CT-ND,448-TLF11251EPXUMA1DKR-ND | TLF11251EPXUMA1 |
| 576-1190-ND | MIC4420YN |
| 296-41797-2-ND,296-41797-1-ND,296-41797-6-ND | UCC27322DR |
| 2156-UCC37322P-ND,296-13689-5-ND | UCC37322P |
| TC1413NEOA-ND | TC1413NEOA |
| 296-13675-5-ND | UCC27322P |
| TC427CPA-ND | TC427CPA |
| MD1210K6-GTR-ND,MD1210K6-GCT-ND,MD1210K6-GDKR-ND | MD1210K6-G |
| MIC4124YME-TR-ND,MIC4124YME-CT-ND,MIC4124YME-DKR-ND | MIC4124YME-TR |
| 576-1447-ND | MIC4123YME |
| TC4420EPA-ND | TC4420EPA |
| TC4420CPA-ND | TC4420CPA |
| TC4420VPA-ND | TC4420VPA |
| MIC4423YM-TR-ND,MIC4423YM-CT-ND,MIC4423YM-DKR-ND | MIC4423YM-TR |
| 576-2322-ND | MIC4423YM |
| 2EDL23N06PJXUMA1TR-ND,2EDL23N06PJXUMA1CT-ND,2EDL23N06PJXUMA1DKR-ND | 2EDL23N06PJXUMA1 |
| TC4429EOA-ND | TC4429EOA |
| TC4424AVPA-ND | TC4424AVPA |
| MD1213K6-GTR-ND,MD1213K6-GCT-ND,MD1213K6-GDKR-ND | MD1213K6-G |
| TC4427AEUA713TR-ND,TC4427AEUA713CT-ND,TC4427AEUA713DKR-ND | TC4427AEUA713 |
| TC4426AEUA-ND | TC4426AEUA |
| FAN3278TMXTR-ND,FAN3278TMXCT-ND,FAN3278TMXDKR-ND | FAN3278TMX |
| 576-1199-ND | MIC4424YN |
| TC4425AVOA-ND | TC4425AVOA |
| TC4423AVOA-ND | TC4423AVOA |
| 448-2EDS7165HXUMA1TR-ND,448-2EDS7165HXUMA1CT-ND,448-2EDS7165HXUMA1DKR-ND | 2EDS7165HXUMA1 |
| TC4429CPA-ND | TC4429CPA |
| FAN3268TMXTR-ND,FAN3268TMXCT-ND,FAN3268TMXDKR-ND | FAN3268TMX |
| 448-2EDF8275FXUMA1TR-ND,448-2EDF8275FXUMA1CT-ND,448-2EDF8275FXUMA1DKR-ND | 2EDF8275FXUMA1 |
| 448-2EDF7275KXUMA2TR-ND,448-2EDF7275KXUMA2CT-ND,448-2EDF7275KXUMA2DKR-ND | 2EDF7275KXUMA2 |
| TC4424CPA-ND | TC4424CPA |
| TC4424EPA-ND | TC4424EPA |
| MD1811K6-GTR-ND,MD1811K6-GCT-ND,MD1811K6-GDKR-ND | MD1811K6-G |
| TC4420CAT-ND | TC4420CAT |
| TC4423CPA-ND | TC4423CPA |
| 448-2EDS8265HXUMA2TR-ND,448-2EDS8265HXUMA2CT-ND,448-2EDS8265HXUMA2DKR-ND | 2EDS8265HXUMA2 |
| 175-MAX25615AUT/V+TTR-ND,175-MAX25615AUT/V+TCT-ND,175-MAX25615AUT/V+TDKR-ND | MAX25615AUT/V+T |
| TC4432COA-ND | TC4432COA |
| TC4432EOA-ND | TC4432EOA |
| TC4432VOA713TR-ND,TC4432VOA713CT-ND,TC4432VOA713DKR-ND | TC4432VOA713 |
| MIC4469YWM-TR-ND,MIC4469YWM-CT-ND,MIC4469YWM-DKR-ND | MIC4469YWM-TR |
| MIC4468YWM-TR-ND,MIC4468YWM-CT-ND,MIC4468YWM-DKR-ND | MIC4468YWM-TR |
| MIC4468ZWM-TR-ND,MIC4468ZWM-CT-ND,MIC4468ZWM-DKR-ND | MIC4468ZWM-TR |
| 576-1215-ND | MIC4469YWM |
| 576-2335-ND | MIC4468YWM |
| 576-1214-ND | MIC4469YN |
| TC4467COE-ND | TC4467COE |
| EL7457CSZ-ND | EL7457CSZ |
| MAX627CSA±ND | MAX627CSA+ |
| MAX4427CSA±ND | MAX4427CSA+ |
| 175-MAX4427ESA+TTR-ND,175-MAX4427ESA+TCT-ND,175-MAX4427ESA+TDKR-ND | MAX4427ESA+T |
| MAX4426ESA±ND | MAX4426ESA+ |
| 296-UCC27322MDEP-ND | UCC27322MDEP |
| MAX626CPA±ND | MAX626CPA+ |
| 296-34709-5-ND | UC2708N |
| TC427IJA-ND | TC427IJA |
| 2EDF7275KXUMA1TR-ND,2EDF7275KXUMA1CT-ND,2EDF7275KXUMA1DKR-ND | 2EDF7275KXUMA1 |
| 448-1EDN7550UXTSA1TR-ND,448-1EDN7550UXTSA1CT-ND,448-1EDN7550UXTSA1DKR-ND | 1EDN7550UXTSA1 |
| 1EDN8550BXTSA1TR-ND,1EDN8550BXTSA1CT-ND,1EDN8550BXTSA1DKR-ND | 1EDN8550BXTSA1 |
| 1EDN7550BXTSA1TR-ND,1EDN7550BXTSA1CT-ND,1EDN7550BXTSA1DKR-ND | 1EDN7550BXTSA1 |
| 448-2EDN7434FXTMA1TR-ND,448-2EDN7434FXTMA1CT-ND,448-2EDN7434FXTMA1DKR-ND | 2EDN7434FXTMA1 |
| 448-2EDN8533FXTMA1TR-ND,448-2EDN8533FXTMA1CT-ND,448-2EDN8533FXTMA1DKR-ND | 2EDN8533FXTMA1 |
| 448-2EDN7533RXTMA1TR-ND,448-2EDN7533RXTMA1CT-ND,448-2EDN7533RXTMA1DKR-ND | 2EDN7533RXTMA1 |
| 448-2EDN8534RXTMA1TR-ND,448-2EDN8534RXTMA1CT-ND,448-2EDN8534RXTMA1DKR-ND | 2EDN8534RXTMA1 |
| 448-2EDN7534RXTMA1TR-ND,448-2EDN7534RXTMA1CT-ND,448-2EDN7534RXTMA1DKR-ND | 2EDN7534RXTMA1 |
| 448-2EDN7533BXTSA1TR-ND,448-2EDN7533BXTSA1CT-ND,448-2EDN7533BXTSA1DKR-ND | 2EDN7533BXTSA1 |
| 497-15507-2-ND,497-15507-1-ND,497-15507-6-ND | PM8851D |
| MCP14A0051T-E/CHTR-ND,MCP14A0051T-E/CHCT-ND,MCP14A0051T-E/CHDKR-ND | MCP14A0051T-E/CH |
| MCP14A0151T-E/CHTR-ND,MCP14A0151T-E/CHCT-ND,MCP14A0151T-E/CHDKR-ND | MCP14A0151T-E/CH |
| 296-UCC37323DRTR-ND,296-UCC37323DRCT-ND,296-UCC37323DRDKR-ND | UCC37323DR |
| MCP14A0151T-E/MAYTR-ND,MCP14A0151T-E/MAYCT-ND,MCP14A0151T-E/MAYDKR-ND | MCP14A0151T-E/MAY |
| MCP14A0153-E/MS-ND | MCP14A0153-E/MS |
| 150-MCP14A0155T-E/SNTR-ND,150-MCP14A0155T-E/SNCT-ND,150-MCP14A0155T-E/SNDKR-ND | MCP14A0155T-E/SN |
| MCP14A0155-E/MS-ND | MCP14A0155-E/MS |
| MCP14A0154-E/SN-ND | MCP14A0154-E/SN |
| 448-2EDL8034G3CXTMA1TR-ND,448-2EDL8034G3CXTMA1CT-ND,448-2EDL8034G3CXTMA1DKR-ND | 2EDL8034G3CXTMA1 |
| 448-2EDL8033G3CXTMA1TR-ND,448-2EDL8033G3CXTMA1CT-ND,448-2EDL8033G3CXTMA1DKR-ND | 2EDL8033G3CXTMA1 |
| 576-1527-5-ND | MIC4428YMM |
| MIC4428YMM-TR-ND,MIC4428YMM-CT-ND,MIC4428YMM-DKR-ND | MIC4428YMM-TR |
| 576-1524-5-ND | MIC4426YMM |
| 576-1797-5-ND | MIC4426ZM |
| 576-1798-5-ND | MIC4428ZM |
| 296-24481-2-ND,296-24481-1-ND,296-24481-6-ND | UCC27424QDRQ1 |
| MCP14A0452T-E/MSTR-ND,MCP14A0452T-E/MSCT-ND,MCP14A0452T-E/MSDKR-ND | MCP14A0452T-E/MS |
| MCP14A0452T-E/SNTR-ND,MCP14A0452T-E/SNCT-ND,MCP14A0452T-E/SNDKR-ND | MCP14A0452T-E/SN |
| MCP14A0452-E/SN-ND | MCP14A0452-E/SN |
| MCP14A0452-E/MS-ND | MCP14A0452-E/MS |
| TC1411NCOA713TR-ND,TC1411NCOA713CT-ND,TC1411NCOA713DKR-ND | TC1411NCOA713 |
| TC1411NCOA-ND | TC1411NCOA |
| 296-25746-2-ND,296-25746-1-ND,296-25746-6-ND | UCC27322QDRQ1 |
| TC1426COA-ND | TC1426COA |
| TC1427COA-ND | TC1427COA |
| TC1428COA-ND | TC1428COA |
| MCP14A0602-E/SN-ND | MCP14A0602-E/SN |
| TC1428CPA-ND | TC1428CPA |
| TC1426CPA-ND | TC1426CPA |
| TC1411EOA-ND | TC1411EOA |
| TC1411NEOA-ND | TC1411NEOA |
| 576-1480-2-ND,576-1480-1-ND,576-1480-6-ND | MIC4120YML-TR |
| 576-1446-ND | MIC4129YME |
| TC426COA-ND | TC426COA |
| TC427COA-ND | TC427COA |
| TC4427VOA713TR-ND,TC4427VOA713CT-ND,TC4427VOA713DKR-ND | TC4427VOA713 |
| TC4426AEOA713TR-ND,TC4426AEOA713CT-ND,TC4426AEOA713DKR-ND | TC4426AEOA713 |
| TC4428ACOA713TR-ND,TC4428ACOA713CT-ND,TC4428ACOA713DKR-ND | TC4428ACOA713 |
| TC4428AVOA-ND | TC4428AVOA |
| TC4428VOA-ND | TC4428VOA |
| TC4427AVOA-ND | TC4427AVOA |
| TC4426VOA-ND | TC4426VOA |
| TC4426AVOA-ND | TC4426AVOA |
| TC4428COA-ND | TC4428COA |
| 296-41798-2-ND,296-41798-1-ND,296-41798-6-ND | UCC27423DR |
| 296-15696-5-ND | UCC37324P |
| 296-UCC27325DRTR-ND,296-UCC27325DRCT-ND,296-UCC27325DRDKR-ND | UCC27325DR |
| TC427EPA-ND | TC427EPA |
| TC1411NCPA-ND | TC1411NCPA |
| TC1411CPA-ND | TC1411CPA |
| 576-2327-ND | MIC4428YN |
| 576-1526-5-ND | MIC4427ZN |
| 576-2314-ND | MIC4420YMM |
| TC4428CPA-ND | TC4428CPA |
| TC4428ACPA-ND | TC4428ACPA |
| TC4427VPA-ND | TC4427VPA |
| TC4426AEPA-ND | TC4426AEPA |
| TC4420VOA713TR-ND,TC4420VOA713CT-ND,TC4420VOA713DKR-ND | TC4420VOA713 |
| TC4420VOA-ND | TC4420VOA |
| TC1411NEPA-ND | TC1411NEPA |
