If you are concerned about the difference between the parts 1007232-3 and 1007214-3 from TE Connectivity Measurement Specialties then you should know that these are not similar parts.
The 1007232-3 is a power plug and 1007214-3 is complete amplifier assembly with power plug. They should not be used as cross replacements for each other.
Applicable Part Numbers
1007232-3-ND
223-1312-ND
