Difference Between APEM Pushbutton Switches – IPR1SAD3L0G vs. IPR1SAD3L0G101
If you’re looking for the difference between APEM pushbutton switches IPR1SAD3L0G and IPR1SAD3L0G101 , please note the following:
The key difference is the bezel finish:
IPR1SAD3L0G: Standard model with a green LED (L0G) and a standard black bezel .
IPR1SAD3L0G101: Same as above, but includes a bright chrome bezel, which is a specific design option.
So, if you prefer the chrome bezel, you’ll need to order IPR1SAD3L0G101 . Otherwise, the standard version (without the suffix) will come with a black bezel.
Applicable Part Numbers
DigiKey Part Number Manufacturer Part Number
679-1120-ND IPR1SAD3L0G
679-IPR1SAD3L0S-ND IPR1SAD3L0S
679-IPR1SAD3L0Y-ND IPR1SAD3L0Y
IPR1SAD3L0G101
IPR1SAD3L0GUL
