Difference between AR0522SRSC09SURA0-DP and AR0522SRSC09SURA0-DR from onsemi
If you are concerned about the difference between the AR0522SRSC09SURA0-DP and AR0522SRSC09SURA0-DR image sensors,
Please see the response below from onsemi.
The difference between AR0522SRSC09SURA0-DR and AR0522SRSC09SURA0-DP is as follows:
  • AR0522SRSC09SURA0-DP = Dry Pack with Protective Film
  • AR0522SRSC09SURA0-DR = Dry Pack without Protective Film
Applicable Part Numbers
5556-AR0522SRSC09SURA0-DP-ND
5556-AR0522SRSC09SURA0-DR-ND
More detail on these suffixes such as “-DP” and “-DR” can be found from onsemi’s website:
https://community.onsemi.com/s/article/Meaning-of-the-DP-suffix-in-orderable-part-numbers-of-onsemi-image-sensors
1.letter
-D = container type is Dry PACK
-T = container type is Tape & Reel
-C = container type is Chiptray
2.letter
-P = with protective film
-R = without protective film
