If you ordered the SOMDM3730-11-1783JFIR Embedded Module from Beacon EmbeddedWorks and received a part labeled ‘SOMDM3730-11-1783JFIR-A’ as the manufacturer’s part number, everything is fine. The manufacturer offers this clarification:
The parts SOMDM3730-11-1783JFIR and SOMDM3730-11-1783JFIR-A are the same device.
The ‘-A’ suffix is an internal code used by Beacon EmbeddedWorks to indicate a specific development phase of the module.
However, the final version, ‘SOMDM3730-11-1783JFIR,’ is identical in form, fit, and function to the earlier ‘-A’ versions.
Applicable Part Numbers
| 460-3514-ND | SOMDM3730-20-2780AGCR |
| 460-3513-ND | SOMDM3730-20-1780AGIR |
| 460-3541-ND | SOMDM3730-32-2780AKCR |
| 460-3552-ND | SOMDM3730-11-1783JFIR |
| SOMDM3730-11-2783IFCR-A-ND | SOMDM3730-11-2783IFCR-A |
